View Poll Results: HP -> Acceleration... not Torque!
HP is more important than Torque
58.62%
Torque is more important than HP
41.38%
Voters: 203. You may not vote on this poll
Old Feb 3, 2005 | 09:18 AM
  #391
foolio's Avatar
Originally Posted by no_really' date='Feb 3 2005, 05:38 AM
Engines aren't pulleys.
You were supposed to imagine the transmission as a pulley
or a lever
or a hydraulic system
Here's an exercise:
Engine A makes 240 HP @ 9000 RPM. It makes a completely flat 140 lb-ft torque from 0 to 9000 RPM.
Engine B makes 240 HP @ 5000 RPM. It makes a completely flat 252 lb-ft torque from 0 to 5000 RPM.
Which engine is better? I could prove to you that A & B are exactly the same (ignoring NVH ).
Old Feb 3, 2005 | 09:32 AM
  #392
Diatomic's Avatar
Originally Posted by AbusiveWombat' date='Feb 3 2005, 10:16 AM
Production car valve trains can't spin that fast. You'll get valve float and bend every valve stem. F1 cars use a completely different valve trainthat allows them to spin to 18000 rpms. They also consist of extremely light metals and on average the engine lasts about 500 miles before a full rebuild...certainly not good enough for a street car that's required to last 100+k miles.
Tho that's true, I think there's a more fundamental issue here. Just because you an spin the S2000 engine to 18,000 doesn't mean it will have the same torque at 18,000 as it did at 9,000.
Old Feb 3, 2005 | 09:44 AM
  #393
FO2K's Avatar
I think we were talking about hypothetical situations. A given engine spinning twice as fast should be able to produce about twice the power. As someone indicated it boils down to the amount of gas burned / unit time.
I know the S engine is not capable of 18K rpm.
Old Feb 3, 2005 | 09:48 AM
  #394
brockLT1's Avatar
there are a ton of 99+ mustangs that have hit 13.8-13.9......food for thought
Old Feb 3, 2005 | 04:20 PM
  #395
neko_cat's Avatar
In any given gear, the torque curve has the same shape as the acceleration curve (torque is proportional to acceleration in any given gear). That proportionality can be shown in five lines of algebra.
Who cares?
I'm trying to point out that your post, and your curves, have no bearing on the original question of whether HP or torque determines how a car accelerates. The constant of proportionality changes every time you switch gears. Your own curves show that you could only normalize the curves in one gear.
You're contradicting yourself. If an acceleration curve has the same shape as the torque curve than it is TORQUE that is determining acceleration! It's that simple.
You see it but you don't. It's right in front of you.
Then you go on to say that the proportionality changes with gear changes. NO IT DOESN'T, the magnitude of vertical scaling changes the proportionality (shape) is still identical. Did you even look at the graph closely? If you did you missed lots of information that is right in front of you.
The only reason scale is matched at all is because my graph is unitless. When your acceleration is measured in +-2 G and HP is 160 all of you acceleration curves would be invisible at the bottom of the graph. Scaling once matches the top peak of acceleration to the highest value in the graph. The following gears shrink from mechanical disadvantage and drag but they still have the same SHAPE.
It does in fact answer the original question of what determines acceleration. It proves it visually. What it doesn't do is tell you which is more useful which is still sort of a silly question. Both are only really useful with all the other variables.
-mikey
Old Feb 3, 2005 | 08:05 PM
  #396
AlanP's Avatar
[quote name='neko_cat' date='Feb 3 2005, 05:20 PM']
Old Feb 3, 2005 | 08:17 PM
  #397
Elistan's Avatar
Wow. Grated, while neko's post doesn't address the question of whether weight along with peak torque or peak hp gives the best indication of a car's general acceleration, his post is spot on about the relationship between acceleration and torque.
You're BOTH correct. You two are just dicussing different topics. Neko about acceleration being proportional to torque, AlanP about power to weight ration giving the best estimation of a car's acceleration.
Why the hostility? It makes me sad.
Old Feb 3, 2005 | 08:52 PM
  #398
speed4tu's Avatar
[quote name='foolio' date='Feb 3 2005, 01:18 PM']
Old Feb 3, 2005 | 09:07 PM
  #399
Elistan's Avatar
Originally Posted by speed4tu' date='Feb 3 2005, 11:52 PM
The car with the more torque is going to pull to the top of each gear quicker than the lower torque car will, therefore making it the faster of the two.
Nope, not correct.
You forget that while car A has 55% of the torque car B does, it can run 1.8 times shorter gearing and hit the exact same speeds in each gear. (1.8 * 0.55 = 1.0)
Therefore it will have the EXACT same torque to the wheels as car B, and will accelerate down the dragstrip at the EXACT same rate.
Old Feb 3, 2005 | 09:59 PM
  #400
AlanP's Avatar
[quote name='Elistan' date='Feb 3 2005, 09:17 PM']
