hp/engine weight, torque/engine weight
You'll have to search the web for engine weight. Some engines are pretty tough to find.
Here's a thread I started a while ago comparing engine weight:
http://forums.s2ki.com/forums/showthread.p...threadid=152112
Also, at rx8forums.com, there's a thread that states that the Renesis (RX8) weighs 303 lbs...not 275 lbs. The 275 was first thrown around but then apparently was changed to 303 lbs. Not sure which is correct now. I'm leaning toward the 303.
Originally posted by 94rexsf
the renesis makes 238 HP (in america, more in japan) and weighs 275 lbs, not including alternator and other accessories.
Im sure it has the highest hp to weight of any n/a engine.
Did you look at the two posts right above yours?
Also, this gets into an interesting part of the equation too. Sometimes it is hard to tell if they are showing weight with accesories, weight with accesories and transmission (which some will put down for the engine weight), or completely stripped engine.
QUIKAG
Aug 4, 2016 10:42 AM
