Ignition Stuck in Lock
Old Nov 3, 2015 | 05:55 AM
scoobydoobydo's Avatar
Default Ignition Stuck in Lock
I have a 2006 CBR 600RR and it only has about 2k miles on it. No issues with the bike until now. I went out to the garage to take it for a spin, and when I tried to push down and turn the key out of the 'LOCK' position, it won't turn.
I've read countless posts about this problem, but no real resolve. I have the spare keys, they don't work either. All of the keys work on the gas tank and the trunk.
List of things I've tried:
1) wiggling the handlebars (whilst attempting to turn the key)
2) shooting air into the keyhole
3) WD-40 in the keyhole
I thought about removing the upper triple but I saw someone else mention that if it is locked, I cannot remove it. I dread dropping the forks anyways...
Mind you, this has been going on for a week. I keep thinking there is a shred of hope that I will walk out to the garage and it will unlock.
Any one have any advice?
Thanks.
Old Nov 4, 2015 | 01:37 PM
Vanishing Point's Avatar
Try a few (5-6) drops of motor oil in the lock, insert your key and withdraw it. Do this several times to coat the internal lock mechanism, then try turning it.
Old Dec 2, 2015 | 11:50 AM
s2000Junky's Avatar
Still locked?
Old Dec 3, 2015 | 03:12 PM
windhund116's Avatar
Is this a spare key? One made by a locksmith. You may need to polish down rough edges with a steel brush on grinder.
Lube the lock and key with 3-in-one of some such lubricant. Be liberal with it. Have someone gently rock the handlebars back-&-forth. You try to turn key at the same time.
iceman86
Apr 9, 2020 10:38 AM
Mr.SweetRoll
Apr 25, 2014 07:28 AM
zenairdave
Feb 16, 2012 06:30 AM
GoldLude
Nov 2, 2011 02:31 PM
Kyras
May 4, 2005 06:45 AM
