Mis-shifted engine
Old May 19, 2002 | 04:11 PM
Mr. Mis-Shift's Avatar
Default Mis-shifted engine
I own an RSX and am trying to find some good advice. I didn't have much luck back at ClubRSX. I just got my new engine back and am concerned about the oil. I keep hearing about special break-in oil that is supposed to be used in new motors prior to using regular oi. I have good reason to think that they did not fill in the new motor with break-in oil. Anyway, what would the outcome be if they hadn't used it? Are they liable for anything? Thanks in advance s2ki members.
Old May 19, 2002 | 06:17 PM
xviper's Avatar
It is still uncertain and unproven that there is indeed "special break-in oil". Any rebuild would have been done with proper "assembly lube" put in all the critical places. With this in mind, I don't think that using regularly available oil would be inadequate. After all, engines have been bebuilt this way for decades. I wouldn't be terribly concerned about it but change your oil early after a rebuild (maybe after 500-1000 miles). Keep track of its oil consumtion during this time and if it doesn't use any (and an RSX doesn't normally use oil during break-in like an S2000 does) you might consider going to synthetic at the change (or maybe the 2nd change).
alanpikku
Aug 7, 2013 12:40 PM
o'malley_808
Sep 6, 2010 11:28 AM
o'malley_808
Jul 20, 2010 05:49 PM
TubeDriver
Mar 13, 2006 01:09 PM
DOUGHS2K
Dec 3, 2005 11:13 AM
