New M5...Weak Output Numbers ?!?!
I just got my new "Automobile" magazine today and they are going over upcoming cars and they had the new M5. Here is what they are saying :
500 hp
369 lb.-ft. of torque
8300 rpm redline
6 speed manual or SMG
0-60 in 4.5 seconds (probably factory conservative)
While that is 31 more hp than the E55, it is a whopping 147 lb.ft. torque LESS than the E55. I hope this is a typo. That is only 1 lb./ft more torque than the current M5. If this is the final figure that is disappointing.
500 hp
8300 rpm redline
What's the engine displacement? It should have more torque if it's over 5.0 liters. Especially in a massive sedan. I say they have a misprint or BMW is slipping further. Peak bhp doesn't mean much, especially (again) in a sedan that won't be used as an interim track day special. Perhaps they've placed this hifh revving jewel of an [sports car] engine in an ubber sedan. If so, BMW needs to redress "Powertrain Matching 101."
ok i cant find the gear ratios for the new M5 but lets use the current M3 and C32 AMG as examples
M3 269 ft lb torque 1st gear 4.23:1, final drive 3.62:1
C32 332 ft lb torque 1st gear 3.59:1, final drive 3.06:1
lets assume the torque curve is relatively flat through the rev range for these two cars ( it is for the M3 )
now you will cry omg omg omg the mercedes has 63 ft lb more torque than the m3. but if u calculate the actual torque being put to the ground
in 1st gear the m3 is putting 4119 ft lbs to the wheels while the mercedes is putting 3647 ft lbs to the wheels. (need to divide this number by wheel radius to see what the torque is to the ground....)
