Parking Light Issue...
Old Nov 13, 2007 | 10:01 AM
8kGoodENuff's Avatar
Default Parking Light Issue...
I'm about to buy a beater Subaru and I wanted to know if you guys could help me out.
I
Old Nov 13, 2007 | 10:19 AM
wickerbill's Avatar
I really have no idea, but maybe it's a bad relay?
Old Nov 13, 2007 | 10:22 AM
vtec9's Avatar
Could be a bad headlight switch or a bad relay. electrical problems are a PITA though.
It could be relay but I'm in the same boat as you... lol. I've never seen this problem before.
Andre
Old Nov 13, 2007 | 10:25 AM
vtec9's Avatar
Well, I've seen some funky things before. I had a car once where the parking lights could come on from the brake pedal switch, and the brake lights would come on with the wipers. turned out to be a crossed wire
Old Nov 13, 2007 | 10:28 AM
So you guys are telling me that this would be a bad idea?
Andre
Old Nov 13, 2007 | 11:22 AM
vtec9's Avatar
Na, I'm sure it's something simple like a relay.
Old Nov 13, 2007 | 11:48 AM
chowmeiniac's Avatar
On my Sti there is a button that keeps the parking light on. Its on the top of the steering column.
They put it there because when the key out of the ignition there is no way to turn on the lights. Try looking for a switch that keeps the parking light on. (it might not be that problem because the parking light should be on at all times)
Old Nov 13, 2007 | 12:18 PM
I've been doing some research here at work and I think you are right... the parking lights should be on. Didn't know that they had them but I'll check it out again tonight. It makes sense because before he turned the car on for the first time, he had to plug in the negative terminal. I guess they don't want the battery to die out... haha.
And as far as the center console lights, it seems that these 90's subarus had a problem where the lights would burn out pre-maturely... so it's a matter of putting in new bulbs.
Thanks Guys. If you guys find anything else, please let me know.
Andre
Old Nov 13, 2007 | 12:49 PM
yellow2001's Avatar
I had the same problem on my sti. it is not a relay. its a dumb ass parking light switch that is on top of your steering wheel. it allows you to turn on your parking lights without turning on your car.
