Plastic composite engines.
[QUOTE=vader1,Dec 1 2009, 11:34 AM] Just a random thought, if they can make plastics that are strong, impact resistant, can stand temp extremes, and can save lots of weight, the most logical use it seems to me would be one piece pickup truck beds.
Originally Posted by Incubus,Dec 1 2009, 04:18 PM
Easy to say. You add a wink like nobody realizes engines produce heat.
Originally Posted by brockLT1,Dec 2 2009, 02:43 AM
right, but the gentlemen has spent the past 40 years trying to design a plastic engine that doesnt melt instead of designing a more efficient engine that doesnt lose all of its power to the laws of thermodynamics.
Originally Posted by NFRs2000NYC,Dec 2 2009, 05:23 AM
I wouldn't even care about the average engine not lasting more than 100K miles, if it cost $599 to replace 90% of the motor...plastic should make it MUCH cheaper to produce.
If a steel engine can last 200k miles but costs 4k brand new and a plastic motor lasts 100k but only costs 1.5k, I'll take the plastic any day.
Originally Posted by Spec_Ops2087,Dec 2 2009, 06:11 AM
That brings up a good point.
I don't think plastic will save much of anything in material costs. Plastic prices are all over the map depending on the type of resin. Basic polycarbonate (PC) is ~$1.30/lb. That puts the price around the same as aluminum per lb. The aluminum alloys actually used in the engines are almost certainly more expensive than the commodity cost of aluminum by a fair margin. However, a fancy engineered resin can easily be $4-5/lb. So per lb we aren't really saving vs alloy. PC is about half the density of aluminum so that does save some cost via weight savings. That would assume that the plastic block is the same volume as the alloy block and that the engineered plastic is about as dense as PC.
The big savings in plastic could come from post processing. Cast surfaces are rough and often require post processing. Plastic parts can often be used as is. A cast alloy intake manifold will have a rough surface finish unless you take the time to polish the whole thing. An ugly plastic part will have near perfect interior surfaces. Snaps and other attachment features can be molded in rather than machined, drilled and tapped after the fact.
There is some potential for cost savings but initially I wouldn't count on it. The weight savings alone seems very compelling. However, I can also see the car companies being very cautious about this sort of thing. Sometimes people accuse them of dragging their feet with respect to promising technology. Well GM was one of the first on the block with aluminum cylinder walls (vs iron liners in an alloy block). That alloy engine did not help the Vega's reputation. A decade later BMW made the same mistake with their V8s.
Given the high cost of recalls and what not I can understand a company not wanting to jump too far. If the idea works your brilliant and forward thinking. If the idea has some sort of failure that only shows up after 5 years you get slammed by the media and any more some class action lawyer is going to try to force you to replace engines that are clearly outside of warranty. The potential to lose is really big.
Originally Posted by Incubus,Dec 1 2009, 06:57 PM
My point is that an engine can only be so efficient. It WILL produce heat, and will never be 100% efficient. You said it, they're laws.
