Random Tech Catalic Converter
Old May 10, 2006 | 08:14 PM
karno's Avatar
Default Random Tech Catalic Converter
Does anyone know where I can buy a Chip to trick the ECU from setting off the check engine light after the highflow catalic converter is installed?
Old May 11, 2006 | 05:37 AM
Wildncrazy's Avatar
It should not cause a CEL. I ran one on my Miata for a couple of years with no probs and I passed emissions tests quite handily.
BTW this cat definitely outflows the stock unit. How do I know? They used my cat to determine flows. Our cat was so good that their 3" jobbie didn't flow enough more to make it worth offering as an upgrade so they went to a 4" cat.
Old May 11, 2006 | 06:25 AM
Umrswimr's Avatar
Correct. You will not need an "O2 Simulator", as they call it, with the RT cats. I'm running sims with my RT cats, but that's only because my LT headers require deleting the second set of sensors.
Old May 11, 2006 | 10:49 AM
S2kracka's Avatar
A mechanical o2 simulator will fix your problem, check my sig!
Old May 13, 2006 | 07:55 AM
Clayman's Avatar
A mech O2 simulator is probably your best bet. I had a Random Tech cat on my Prelude, and very sporadically, I'd get a CEL. It would go away for months at a time, and then all of a sudden pop up. I called the guys at Random, and they said it was just one of those things that happens when the circumstances are just right. Not a big deal for me (although the CEL is a PITA), but I never tried any mods to fix it. Good luck.
Sep 25, 2013 03:22 PM
RL1924
Jul 7, 2009 04:41 PM
jamieM
Apr 12, 2007 02:00 PM
Fastlane
Oct 16, 2001 08:59 AM
