Sick Engine, Brammo V-12
Old Feb 23, 2006 | 10:06 PM
Urge's Avatar
Sponsor
Default Sick Engine, Brammo V-12
http://www.brammo.com/index.php?option=com...d=31&Itemid=102
WEIGHTS & MEASURES
- 600 CID (9.85L)
- 522 LBS.
- 4.125
__________________
Old Feb 23, 2006 | 10:07 PM
SpeedxRacer's Avatar
Veryon > that
Old Feb 23, 2006 | 10:20 PM
pantyraider's Avatar
So are you supposed to sit on the engine while it magically takes you to 240 mph? The Veyron is more than just an engine. Its the packaging of the body, cooling systems, aero peices
Old Feb 24, 2006 | 01:40 AM
tafka TMB's Avatar
Wasn't that originally going into a stretched carbon-fibre clubman thingy?
Old Feb 24, 2006 | 01:57 AM
Shinigami's Avatar
How much power does it get without race gas? I would kinda "expect" high HP numbers from a 10 liter engine... The Veyron's engine is however smaller and runs on standard gas.
Old Feb 24, 2006 | 05:53 AM
bkw's Avatar
bkw
Since Brammo is the NA disty for the Atom.. I wonder if they can stuff that motor in the Atom.
Hmm.. the damn motor probably weighs more than the Atom chassis thus making it a wheelie monster!
Old Feb 24, 2006 | 06:06 AM
JonBoy's Avatar
That's a motor. What about a reliable transmission?
It is moderately easy to make a high-powered motor. You can literally order parts from any of a number of suppliers, bolt it all together, add a huge cooling system, and away you go.
Building a system that can handle that power is a whole different story. The delay on the Veyron was the transmission, not the engine.
So yes, that's a sick engine. But it's only an engine, not a car.
Old Feb 24, 2006 | 06:20 AM
Urge's Avatar
Sponsor
They Veryon Engine weighs in at 900+ lbs and needs 20 psi of boost to get 1000 hp.
This engine is NA and weighs in at 500+ lbs. I hope you can see the engineering in this.
Race gas usually adds 10%+ hp.
__________________
Old Feb 24, 2006 | 06:53 AM
Elistan's Avatar
More information from the manufacturer of the engine:
http://www.falconerengines.com/spec_v12low.htm
(They're designed to accept Chevy bell-housings, by the way. And they're targeted at custom hot rod and marine markets.)
[QUOTE]
Old Feb 24, 2006 | 07:20 AM
JonBoy's Avatar
So you'd actually have to run a race engine in a street car to be in the same league as a Veyron...
