Trade an '06 STi for an LS1 FD?
Hello, folks.
I would appreciate some opinions from you guys who know better about STis and FDs.
A friend of mine has an '06 STi w/ FMIC, exhaust, BOV, Cobb tuning(custom tune), Defi gauges(for show mostly... he's got 5 gauges with controler).
He also has some audio upgrades(speakers, sub, Clarion display)
Currently has over 30k miles on it.
He got an offer to trade his ride w/ an LS1 swapped '93 Mazda RX-7.
My friend says it's in stunning condition w/ a fresh paint job(gunmetal) that's been recently done.
Stock wheels, suspension, no body kits whatsoever.
The guy says the LS1 has 40k miles on it. And he's offering an even trade.
Do you think it's worth it?
I honestly don't know the value of an LS1 swapped FD, so your help would be appreciated.
Thanks, guys.
EDIT:
Here's more information about the FD
Oh, and my buddy's car has header & up-pipe as well.
This car started off as a 1993 touring model that was originally Montego Blue, but has had a full color change by a professional bodyshop to 2004 Corvette Medium Spiral Grey Metallic.
Interior:
Brand new black carpet and rear hatch carpet
Mazda RX7 R2 model suede black leather seats
4 point Sparco Harnesses
Black interior in great condition
Sunroof
Shaved rear wiper arm
Kenwood head unit
Optima Redtop relocated battery with a circuit breaker shutoff in the rear storage bins.
PLX Wideband O2 sensor and digital readout
Factory gauges all work
Engine:
LS6 Block with 40k original miles
New LS6 Heads with sodium filled exhaust valves
LS6 intake manifold
Diamond forged pistons
Je total seal rings
Balanced and blueprinted engine
GM MLS head gaskets
Thunder Racing T-Rex Camshaft
PRC dual valvesprings/titanium retainers
Texas Speed Chromoly pushrods
Comp lifters
Clevite coated cam/main/rod bearings
ARP 12 point head/main studs
ARP 2000 Rod bolts
Callies Compstar rods
New oil pressure and temp sensors
1 3/4" Ceramic Coated Long Tube Headers with V-bands
Hinson Supercars Deluxe mounting kit
Aluminum driveshaft
Custom Aluminum Radiator
Slim FAL Cooling Fan
Walbro 255lph high pressure fuel pump
Corvette fpr
Delphi 42# injectors
LS2 timing chain
New GM engine seals/gaskets
LS1 engine wiring
1999 LS1 Ecu
LS1 MAF sensor
Polyurethane filled motor mounts
ATP rubber intake elbows
Dual 3" pipes to single 4" pipe
Two 3" Magnaflow cats
Hooker Aerochamber 3.5" muffler
Magnaflow exhaust tip
K&N Cone Filter
3.5" Custom Air Intake Piping
HPTuners Pro engine management
Drivetrain:
T-56 6-Speed transmission
Spec stage 3+ Clutch
Spec billet flywheel
US Brake clutch master cylinder
Stainless Steel Braided Clutch Line
Heat Wrapped Clutch Line
SGI-5 Speedometer Correction
New LS6 slave cylinder
Steeda Tri-Ax Handle
03 Cobra shift knob
New GM Transmission Mount
Insulated transmission tunnel
Exterior:
New OEM Mazda Weather Stripping
New BFGoodrich G-force T/A tires
Slotted Brake rotors
Stainless Brake Lines
Rotary Extreme HID headlight conversion
99 spec tail lights
Full Color Change including door jambs, trunk, engine bay
Extras:
HP Tuners Pro CD
Sparco Harness
Black seatbelts
Footrest(this car didn't have one so I just bought it but didn't put it in yet)
Super Pro urathane bushing kit
LSX AC lines
AC pressure switch adapter
new passenger side window switch
The car is built to rev to 7500+ rpm and the bottom end is proven to hold up to 800 or so hp. My plan was to run a 150hp wet shot of nitrous on the car eventually which would put the car around 600 rwhp which is enough to get the car into the 9's with traction given the cars 2700 lb curbweight. The car is fully street tuned and can be daily driven if you want. Judging by similar setups, this car should make over 430 rwhp with ease. The car has over $25,000 invested into the swap and the paint.
Dan
Thanks, guys.
EDIT:
Interior:
Sunroof
Kenwood head unit
Engine:
LS6 intake manifold
Je total seal rings
GM MLS head gaskets
Comp lifters
ARP 2000 Rod bolts
Aluminum driveshaft
Corvette fpr
LS2 timing chain
LS1 engine wiring
1999 LS1 Ecu
LS1 MAF sensor
K&N Cone Filter
Drivetrain:
03 Cobra shift knob
Exterior:
99 spec tail lights
Extras:
HP Tuners Pro CD
Sparco Harness
Black seatbelts
LSX AC lines
Dan
Originally Posted by cravnpup,Jan 28 2008, 06:27 PM
[biased WRX owner]
Keep the STI. It's worth more, can be made just as fast or faster, and will likely be more reliable.
[/biased WRX owner]
[/biased WRX owner]
06 WRX > gas guzzling muscle car engine anyday. He's offering an even trade because he knows that a normal person would ask for cash on top. Seriously .. I don't care if the LS1 swapped FD can run in the >10 quarter mile bracket. If he isn't willing to put some cash on top, its a no deal foo!
hahah. the ignorance of most import owners as to the LSx is funny. heres a motor more than double the size of most jap engines. makes more power in stock, NA, boosted forms and still get 30+mpg on the hwy.
most LS1's can crank out 500whp easily with as little as heads/cam. most make 600whp+ on 6-7psi of boost. and last but not least most of all these engines are all over 100K miles, some into the 200k miles areas. for the cost of a 500whp STi, you could come close to DOUBLING that whp number in an LS1. get a grip guys, this "low-tech" OHV, 16valve v8 will DESTROY most imports with hardly a breath.
the ls1 also wieghts less then just about every jap four banger produced.
sincerly,
VJDM
WRX owner(in 2weeks)
sincerly,
VJDM
