wont start in first gear?
i have a cbr600RR 2006 and im having an issue with the bike not starting in first gear...so i saw that with the
clutch in,
the kickstand up and i
n first it wont start...
it will only start if i have it in neutral..it worked fine before i had it garaged for a month and before i had starting issues (Just needed a running start)..but does any one have any ideas...i havent really messed with it js yet...but if any one can shoot some ideas before i take a look that would be great.... t
hanks in advance
Josh R.
clutch in,
hanks in advance
Josh R.
no its fine when its started up...goes in gear perfectly...its just when its off in order to turn it on it has to be in neutral in cant be n any gear....im thinking its something with my kickstand safety switch or the clutch safety switch.....
Josh
Josh
I'd say the same thing, kickstand sensor, but not if he can start it in neutral and it doesn't stop when he puts it in gear? Sounds more like a clutch switch failure (don't know if that bike has one). Because that might not need to be "made" to start in neutral.
Maybe kickstand switch, but that's weird if it doesn't die when you drop into first gear...
Are you sure you used to start in first and not neutral before you put the bike away? I just found out last month that 07 ZX6Rs doesn't start outside of neutral. Found this out while queuing up to get out on track; talk about embarassing. haha.
yea im thinking it is has something to do with the clutch switch sensor....its not the kick stand because as soon as its running n i put it in gear it stays on...if it was the kick stand sensor it would shut off as soon as i put it in gear.....im prolly just going to replace the clutch switch sensor....
thanks for the help
Josh
thanks for the help
Josh
You garaged it for a month and then started having issues?
Charge your battery.
I'm guessing that while it's in gear, even with the clutch engaged, you have some friction there and theres not enough juice to kick the starter over with the added load.
Happens all the time on mine, I'll park in neutral, turn off the bike, side stand down and then I put it in gear.
When I go back to start it, while it's off I put it in neutral, clutch in, hit start and it jerks a bit like it's still in gear even though it's not and the clutch is in and the starter sounds like its under more strain than if I just leave it in neutral when I park.
Just a guess...
Just a guess...
