Mid-size or Full-size SUV that can tow
Ford Expedition 5.4 V8, 2007 or later will tow at least 6000 pounds (9000+ "properly equipped") and the engines run over 200,000 miles routinely. These ride like Town Cars. I've had one with the 5.4 V8 and currently have the 3.5 EcoBoost which I currently drive and tow with.
-- Chuck
-- Chuck
Volvos are tanks and from most accounts very reliable. I would personally stay away from the domestics. They become more junk as they age. Toyotas, and especially the ones you listed, age well and are uber reliable. I wouldn't buy a domestic with 100k miles, but that's my opinion. Entry cost will be higher with the Toyota, but it'll retain it's value and be reliable. What are you trying to tow? JonBoy is more on point. Brakes, tranny, and cooling are more important. It's stopping that becomes a bigger concern than getting the weight moving.
As far as towing, it will be mainly snowmobiles in the winter. Every once in a while I'd like to be able to tow a car, but that will not be too often. I like to be self-sufficient and be able to run down to U-haul, rent a trailer and throw a car on it instead of having to find someone to borrow a bigger tow vehicle from.
3d Generation Expeditions ('07-'17) have all coil spring suspensions on 95% of them with air leveling on some high trim lines -- which I avoided. These are on full frames with the tow receiver connected to the frame. 9" of ground clearance (but so does my Outback). Part time 4WD (2H, 4A, 4A,4L) dash selective. Limited slip differentials optional but usually on the HD Tow versions. Off road performance is tire dependent. "AT tires never got me stuck. Real off-road tires would be better of course. These ain't rock crawlers, they're 6000 pound trucks. I believe they all have 7 or 8 passenger capacity and the 2d and 3d row seats fold. My 3d row is typically covered with a HD cargo mat and rarely used for seating.
The young couple who bought my '07 last summer was thrilled it only had 180K miles on it. Their pickup had close to 300K. Same 5.4 V8 and they were keeping the pickup too.
-- Chuck
-- Chuck
I also had the LX450 and LX470 and towed a car with both. The 470 towed well, but CHUGGED fuel when towing at about 7-8mpg. The Touareg doubles that towing the same load and handles it better. It makes over 400 ft-lbs of torque (and APR tunes are available). The american SUV options will all be cheaper.
My Touareg TDI was flawless in terms of reliability. Oil changes, tire rotations and fuel filter changes and that was it. Regularly towed 6000 lbs with ease. It got 30mpg on the highway and had a range of over 700 miles. Mine was a 2015. Perhaps the older ones had issues? I wouldn't buy the V10 TDI.
It drives like a gutless turd, but has the same tow rating.
