The one car I’d give my S2000 for...
#81
That gets old. It's rewarding hearing the flappy gearbox rev match on the way down, snapping gears off like Schumacher into Maggots.
#82
You know the 370z has an auto rev match feature in their manual trans when you downshift and BMW has a great engine audio system as well. Lots of trick stuff these days for those who like to pretend.
#83
On my manual cars, I want it a regular old manual. I would rather double clutch or rev match on my own. I like the hill start feature on the Porsche; not sure who else has the same feature. It does make starting on a hill easier and lighter on the clutch. When the paddles are good, I would rather have them than the manual. Not all paddles are good iterations of that style gear box. Our XE had an 8 speed ZF and it was lousy. The similar gear box on Maserati is fun.
#84
Slow your role, your car has synchros and abs.
#85
#87
#88
ChiHonda (05-16-2019)
#90
Not sure if you had a supercharger on that car but that added 70lb over the nose on your current will slow turn in down a little bit, not drastic but perceivable to a degree. Assuming you currently have an Ap2 the slower ratio steering rack will also slow down the sharpness and so will the softer rear sway bar and 80lb heavier weight of the car compared to the 00-01 ap1. Quite a few potential factors, most of which can be addressed though. Nothing magical about one s2000 over another, other then set up/tuning and nostalgia.
