Saving money with a diesel engine?
#21
I've been kicking around the idea of picking up an old Mercedes diesel and converting to bio diesel. Just not sure if I could find a MINT vintage Benz with A/C and service records in my price range.
Either a W114/115:
Or a W123:
Either a W114/115:
Or a W123:
#22
Had a buddy that bought one, looked good going in, and it turned out to be a money pit. It may be the price of the car overall, but my memory is that Mercedes only charges about $1200 for the diesel option on the E series.
#23
If you are worth $500/hr, then guying gas is not a problem at all. You could have sent an intern to fill up the tank for you.
#24
On the highway I get low to mid 50 MPG in my diesel. In the city mid to high 30's. I'm averaging low 40MPG thus far with mixed driving but the motor isn't broken in yet and I've been told (and read) that MPG will go up once it has some mileage on it. The thing with my diesel (I test drove all the hybrids) is it has an extra 100 ft lbs of torque at the crank. That is a massive power stat over hybrids. It means my diesel has excellent passing power. While not quick off the line, while rowing gears in 2-4th, it has good acceleration. You really notice the torque when hauling stuff, it has enough power to move some weight and doesn't get bogged down.
It also has a manual transmission option, something you won't find in an Insight or Prius. I can't stand slushboxes or CVT transmissions and thankfully VW had MT options so I got the 6 spd.
It also doesn't have to worry about expensive batteries, EVER.
It also can run on bio-diesel. This is something my friends and I are pondering right now (2 of my friends have Jetta TDI's). At some point in the future, perhaps when we hit $5 a gallon, we will jointly invest in the equipment and start making our own fuel and it's significantly cheaper than gasoline or diesel by a stretch.
The diesel engine easily outlasts gassers. On the TDI forum, there are plenty of folks at 500k miles and then some. The motors just seem to keep going like the energizer bunny.
Where I live, diesel is more expensive than 87 octane but $.10 cheaper a gallon than premium, which my last few cars took. (S2k, STi, RSX Type S, Civic Si) So coming from cars that required premium unleaded, I'm paying less per gallon. Another added benefit is less trips to the convenience store to get fuel, or Costco, where I used to go. Costco often had lines for gasoline, and either way, less time out of my week, albeit not huge amounts of time.
The main reason I picked it up over any Hybrid is driving dynamics. There was just no comparison in driving the TDI vs. the popular hybrids, absolutely none. While it's not a performance vehicle by any means it sure drives well and murders the popular hybrids in terms of handling.
http://www.insidelin...twagen-tdi.html
The Winner
We understand the rationale behind the Prius V wagon. It's a natural progression from the smaller hatchback, and quite frankly we wonder what took Toyota so long to bring it to market.
That said, the Jetta SportWagen TDI is simply more rewarding to drive in nearly every situation. Modern turbodiesel engines do not rattle, smoke or smell, nor are they inherently underpowered or slow. You don't have to go to truck stops to fuel them anymore either. Today, turbodiesels offer an undeniable alternative to hybrid-powered vehicles that, while providing a slight advantage in terms of fuel efficiency, also are rife with intrinsic concessions in terms of driving dynamics.
We know it sounds like we've beat this drum before, but the Jetta drives, looks and simply behaves more like a "regular" wagon. Call us crazy, but when we press the accelerator, turn the steering wheel or even want to manually select a gear, the Jetta SportWagen actually goes, turns and shifts like we expect. It's something you can't see in the numbers, but you feel every time you're behind the wheel. So as this rivalry goes, score another round for the diesel.
It's baffling reading these types of threads about these type of vehicles. People will just go off a sheet of paper and driving dynamics gets absolutely discarded. Many think that these cars are a purely economical choice and feel, handling, etc, go out the window and it's simply about $ when we all know whether it be a TDI, or a S2000, there is much more about the car than what a stat sheet says. Driving dynamics hasn't even been discussed in this thread until now, which is pretty sad for an enthusiast forum. Why can't you discuss which one drives the best while discussing sippers?
The 2nd major reason I bought one, was the resale value. It's high. While doing my research I found used SportWagens going for not much less than new and they are hard to find in a manual transmission. They hold their value extremely well and is what led to my purchase. The higher fuel prices go, the better the resale value will be. Compared to my last car, higher fuel prices would mean more depreciation and it would be much harder to move.
I see no reason for hybrids, none. They are slower in passing, merging, etc, drive much poorer, don't have manual transmission options, won't last as long, are more complex with no added benefit, and don't hold their value as well. Slightly cheaper fuel, but less MPG in my real world testing. And they absolutely cannot run on alternative fuel whatsoever. Price is moot as a Prius with Nav vs. a TDI with the same options such as the Prius V vs. the SportWagen, well there is a negligible price difference.
Just wait until VW rolls out their Hybrid Diesel, you might have an argument then.
#25
I like the ideal of a diesel motor to save money on gas costs. I thought the "numbers" worked out better than they actually do though.
On Fuelly a 2011 Golf TDI averages 42MPG while the 2.5L gas averages 30MPG. With the current fuel prices in my area, this works out to:
TDI - 10 cent per mile
Gas - 13 cent per mile
Going to the VW website and configuring the car, the diesel option for the Golf is *five thousand dollars*. Wtf?!
At three cent per mile benefit, you won't break even on fuel costs until 167k miles. Little wonder diesel engines in passenger cars aren't making any headway in this country. Why are they so damn expensive?
#26
I see only one post above discussing the longevity of the diesel engine vs standard. Diesel life expectancy can be measured in millions of miles, not hundreds of thousands. This is a HUGE factor when considering a diesel.
#28
For example (not necessarily his numbers)
$4.25/42MPG = 10 cents per mile
$3.90/30MPG = 13 cents per mile
#29
Originally Posted by NFRs2000NYC' timestamp='1335031562' post='21630113
[quote name='deepbluejh' timestamp='1334854606' post='21623707']
[/quote]
That's correct. Those were almost the exact numbers I used. Where I live regular gas is about $3.90 and diesel is about $4.20. These are average numbers, and they will surely fluctuate over the life of the vehicle, but the overall price difference between the two fuels should be fairly constant unless the tax situation here in this country changes (don't hold your breath).
#30
I guess that goes along with resale value... as a diesel will surely fetch more money when it comes time to sell the car. If your numbers are even close to true, the rest of the car is going to fall apart before the diesel engine itself dies.
