Scott's Camber Tires
Old 04-28-2010, 09:53 AM
Saki GT's Avatar
Red face Scott's Camber Tires
http://www.automobilemag.com/features/news...ires/index.html
Written by someone with a loose grasp of automobiles (or at least tire treadwear ratings), but an interesting article and concept.
Personally I'd go for some camber tires - its not like I'm rotating them now.
Old 04-28-2010, 10:57 AM
aklucsarits's Avatar
I find it difficult to believe how this guy was able to get a patent on cambered tires in 1999. There are lots of prior art examples out there.
Tire makers like Hoosier and BF Goodrich were making cambered tires for autocross in the 1980s and NASCAR started using them in the early 1990s.
Andrew
Old 04-28-2010, 11:00 AM
Mr.E.G.'s Avatar
I am quite skeptical of this. I have MUCH More to add but I am on my phone typing this and I will have to wait until I get to a computer to elaborate. In a nutshell, static camber means dick compared to dynamic camber which is much more complex than adding tires with 2 degrees of negative camber built in.
Old 04-28-2010, 11:51 AM
00CivicSi's Avatar
The Camber Tires ride as if they're filled with marshmallows instead of cement.
He also hopes to produce what he calls 'square' tires -- radials with identical compounding and construction, minus the camber feature -- to facilitate more equitable comparison tests.
Old 04-28-2010, 11:52 AM
asrautox's Avatar
So looking at the test results, the stock tires launched better and produced higher steady state cornering than the 140 TW rated camber tires. Looks to me like these things don't work. I wonder why they left out standard r-compond tires to compare..
Old 04-28-2010, 12:06 PM
JonBoy's Avatar
I liked the statement that the R-compounds gave 4% better cornering increase and 6% reduction in braking distance compared to the Advans, as if they would otherwise be (without their "cambered" profile) roughly equal to the stock Advans on the Evo.
Sorry, someone doesn't know their topic very well.
Old 04-29-2010, 11:45 PM
GinoGT's Avatar
So the negative camber that's dialed into just about every car to improve it's lateral grip....this tire tries to get rid of it.
Old 04-30-2010, 04:57 AM
Saki GT's Avatar
No, the tire is designed to lean, so if you have 2° camber, instead of the outside of the tire being off the ground normally, the tire will have a full contact patch. When you corner and the car rolls over, the tires are supposed to have a full contact patch the whole time while a traditional tire with camber would increase contact patch as the car rolls over.
Old 04-30-2010, 05:14 AM
omairtheman1's Avatar
I don't really get the point of this... the reason for camber is during aggressive cornering or acceleration to give more contact. How would this help?
Old 04-30-2010, 06:38 AM
JonBoy's Avatar
Because a tire with negative camber doesn't have 100% contact. The outer portion of the tire is off the ground in some form or fashion. With this tire, the negative camber is built into the tire so you get 100% contact at all times (theoretically, at least).
Quick Reply: Scott's Camber Tires
