4 wheel drifting.
Old Aug 7, 2011 | 03:25 PM
soulcrew's Avatar
Default 4 wheel drifting.
good init.
did it 4 times today on some roundabouts.
toyo t1r's rule.oh and the fast road setup from cog.
also the v8 is a very good learning aid
Old Aug 8, 2011 | 02:37 AM
veehexx's Avatar
farking loonatic
Old Aug 8, 2011 | 02:39 AM
RichwiththeS2000's Avatar
Whats the difference between 4 wheel and 2 wheel drifting?
Surely if the front wheels wern't drifting as well you'd actually just be spinning?
Old Aug 8, 2011 | 02:57 AM
BSM139's Avatar
UK Moderator
Not sure if this the right answer, but....
2 wheel drive car = 2 wheel drifting
4 wheel drive car = 4 wheel drifting
BTW - moved to correct forum
Bharat
Old Aug 8, 2011 | 05:37 AM
Nottm_S2's Avatar
Niether of SCs cars are 4wd so one of you is wrong...
Although without 4wd i'd suggest its just sliding so i'm backin bharat (plus SC is a cardiff fan and they robbed earnshaw without paying a penny)
Old Aug 8, 2011 | 06:42 AM
Dixon Motorsports's Avatar
No, 4wd drifting is mean all 4 tyres exceed the maximum grip limit and slide it into the corner. Is one of those thing all racing driver try to do on every corner.
It actually mean understeer and oversteer at the same time, is very hard to do as you have to get into the corner over the speed you can normally do to get it the front slide in and you also have to brake into it at the same time to get the backend out. I can only do it when everything setup is right on the car and no cars around me on the track...
Don't try it on the road!
Old Aug 8, 2011 | 06:44 AM
MB's Avatar
MB
Member
Used to do it a lot on the road in my Imprevo days
Old Aug 8, 2011 | 06:53 AM
Nick Graves's Avatar
I could get superb ones on S-02s.
Got one in the Prelude once; but that was when I was on a mission & the road surface had softened on a hot day.
Old Aug 8, 2011 | 10:03 AM
chilled's Avatar
a tiny amount of 4 wheel drift is the perfect cornering speed.
Makes you feel like a proper man too
Old Aug 8, 2011 | 10:27 AM
jimmyb1978's Avatar
Only done it once in the S with T1Rs too and it does give you right to wear Old Spice
