Automatic gearbox change
I've done most jobs on cars but never changed an auto gearbox
One of my cars now needs a new 'box and given that it isn't a one tonne version for the Daimler and that they seem to be cheap secondhand I'm considering giving it a go
Is it more diificult than changing a manual with clutch?
In my simple mind it's going to be easier, like a one component swap, but is it?
I've not done one, but yes, in theory it's more-or-less the same.
Remember to drain the oil from the torque converter before unbolting it from the flywheel - that's where most of the ATF lives.
I should imagine the biggest problem is getting precisely the correct spec unit, to talk to your ECU properly. Not all ZF 6HPs are born equal.
There's quite a history of converting NSXs and Preludes from auto to manual, so what you're proposing ought to be much more straightforward.
Yes, it's quite popular-ish, for some reason. Probably related to autos being relatively cheap & commonplace.
Especially if they want to rice the 3.0 engine, the torque-area profile camshafts are likely to be ditched, anyway. So it's not really a disadvantage.
(apologies Gad)
my delusion was short lived
perceived wisdom was always that the NSX conversion was difficult and not cost effective
I suppose the current asking prices for manuals may have changed that
still be a conversion ateotd though
only irrelevant if you plan to keep the car forever
