Beater-nomics - the deed is done
As I mentioned in my Alfa shunt thread, I've just been offered more than I expected for the 156 but this means I now need to find alternative wheels pronto.
I was/am thinking in terms of a reliable runaround for about £3.5k, but whilst nosing around the car lots this morning, I came across a beautiful looking Merc 300CE. It's an F plate so it's a 1988 or 89 car, ie. 20 years old.
However, there wasn't a spot of visible rust on it and, per my understanding anyway, Mercs of that vintage date back to an era when they were virtually bulletproof. I know, and I'm sure plenty of you on here know, of 20 year old Mercs that are still running around and looking good.
I took two better photos with my phone, but for whatever reason, they're corrupt so this is the only one ...
This car was up for £1,495, so against my budget, I'd have some money in the pot should something expensive need sorting.
My question is, am I better to spend my £3.5k on a reliable, Japanese, but slightly dull box, or be a bit different and go for a "proper" car? Personally, I'd rather be seeen running around in the Merc than in some anonymous Avensis, Accord or Mazda.
Does anyone disagree with my theory that Mercs from the 80s were better built than later cars? I haven't test driven this one yet, but my question relates to cars like it. Just as I scratched the Alfa itch, something inside wants to scratch the Merc itch ...
Last of the good ones those - front wing looks a different colour to the door ...
Quick HPI check and why not, something different to bowl around in for a while.
My last house mate bought an old M535i BMW of the same age but for half that price and it ran for a year until it fell to bits, same as the 520i he had for 12 months before that.
get it with a year's MOT, decent tyres, all brakes ok and nothing obviously in any way suspect with the engine and 'box
and you can't go far wrong
then, resist the temptation to fix everything that could be fixed - the odd dash bulb, bits of trim, etc or you will spend more on the car than it is worth
you could probably get the car for £1200 cash (I'd offer them a grand)
not exactly a high risk proposition
I'd say your downside would be limited to £500 (purchase price less what it might fetch in parts/ebay)
The W124 was a proper M-B indeed.
You don't state the mileage, but they will do interstellar.
Like Gad say, if it checks out, what yo gotta lose?
Might have another 10 years in it, especially if it's the old two-valve head. The four-valves were occasionally troublesome.
Interesting comment about not getting carried away fixing things. I suppose my only concern is that something major is waiting to go and does so torpedoing any sale.
Good spot on the front left wing. Looks like a respray or replacement ...
get in a ramp and check out the exhaust and bottom of the rad as well
cheapest pre-purchase check you can get is to put it through an MOT test at a garage you trust - and give the tester a drink
I'm aware these things can do huge mileages ...
for example:
engine - smoking, noises, mayo, leaks
box - slow to engage (assume it's an auto), slipping when changing, don't forget to test hot and cold and don't forget reverse, fluid colour, leaks
exhaust - no rust, no leaks, check carefully at the manifold
central locking - either works perfectly or it doesn't
heater - ditto
wipers - ditto
discs and pads - easy to check for condition, lifespan
check warning bulbs haven't been removed rather than blown
headlamps (every other light will be cheap and easy to replace a bulb)
if the engine and gearbox pass as satisfactory, it's just fate if something major goes
but far more often than not, the signs are there - buyers just don't spot them or choose to ignore them
after that, you are into trim, and this is where it's easy to get silly fixing things
As far as I remember Merc only stopped building cars properly when they bought they bought Chrysler about 10 years ago.
