Changing anti-freeze
Old Jan 16, 2010 | 05:37 AM
mikdys's Avatar
Default Changing anti-freeze
I'm shortly going to be carrying out 10 year service on my wife's Ford (I plan to change cambelt, filters, plugs, brake fluid, etc).
The cooling system has never lost any coolant, still has a "good s/g" on an anti-freeze tester and I understand that the "Ford Pink" coolant is supposed to have a 10 year corrosion inhibitor lifetime.
One question is: "how necessary is it to change anti-freeze to ensure no corrosion"? Another is: "what is likely to corrode and cause problems if the anti-freeze is not changed"? (It's an all aluminium engine.)
I'm thinking that changing the A/F is going to add quite a lot to an already expensive parts bill and could be a PITA to change (bleeding heater etc).
Any comments?
Old Jan 16, 2010 | 05:50 AM
Nick Graves's Avatar
Originally Posted by mikdys,Jan 16 2010, 02:37 PM
..."what is likely to corrode and cause problems if the anti-freeze is not changed"? (It's an all aluminium engine.)...
All of it could corrode!
It's a few quid & not difficult to do.
Old Jan 16, 2010 | 06:17 AM
GaryB's Avatar
It's the hassle/cost vs peace of mind equation.
As Nick says, it's not a huge hassle or cost considering what else you're already doing so I would if it were me.
Certainly no more hassle than changing brake fluid.
Old Jan 16, 2010 | 09:27 AM
A LOT hassle less than bleedin' ABS!
That can be a f ucking nightmare.
Old Jan 16, 2010 | 09:29 AM
mikdys's Avatar
Thanks for the replies - maybe I will change it (websearch on this engine suggests they can suffer from core plug problems).
Any opinions on "Halfords Advanced Antifreeze" (the Ford stuff is damned expensive)?
Old Jan 16, 2010 | 09:55 AM
Not a clue. Probably made by someone reputable.
I tend to prefer OEM Honda stuff, for mixablility purposes if it ever needs topping up. Which it doesn't...
But yeah, I'd use Comma or whatever from the local factors, otherwise.
Old Jan 16, 2010 | 11:44 AM
mikey k's Avatar
The Ford, Comma and most stuff on the market are made to an EU standard (no surprise there!) so are as good as each other.
IIRC there are two types/mixes - one is green the other pink.
I did the S2000 when I upgraded the rad. PITA to bleed and left me panicking about warping the head
ATNCHN
Aug 9, 2015 05:16 PM
s2krazy01
Dec 5, 2011 02:19 PM
Bob A (SD)
Aug 26, 2008 02:56 PM
comets
Feb 5, 2004 04:35 PM
mountainrebel
Jun 9, 2002 04:38 AM
