Dumb Brakes
I hate everything to do with drum brakes. They look like the most complicated thing since the Subaru Impreza engine.
The drums on my Fiesta I had as a teenager (thankfully the only car I've owned with the horrid things on) used to make the car fishtail at 30mph.
going to be fitting drum brakes to the race '63 Corvette Stingray i look after as it was never produced with discs for that year .
the powers that be are clamping down on cheat cars so they have to be to homolagation spec so the vented discs will be removed
drums are military spec cryogenically treated so they are denser to dissipate the heat better. there will be big "elephants ears" to direct cold air into the brakes and inside the brakes will be fans to move the air around
(ZO6 had these fans and ducts in period
the 400hp FIA engine i built last year is holding up well, i just hope the brakes will do the same
(as long as the adjusters are working properly)
)the 400hp FIA engine i built last year is holding up well, i just hope the brakes will do the same
(as long as the adjusters are working properly)Russ.
Wow they look serious stuff
Adjusted the handbrake adjuster right back this aft but in my rush
to escape the rain I knocked out one of the pistons in the slave
cylinder.
Bollocks, had to bleed the circuit in the rain on Christmas eve
Russ.
cylinder.
Russ.
