garage damp problem
Old Oct 24, 2016 | 12:20 PM
S2K-Phil's Avatar
Default garage damp problem
How difficult and expensive is it to take a garage with single brick walls and, probably, no damp proof under the concrete floor, and make car friendly. I want to put my car in it but it will rot/rust faster inside than out as it is damp?
I'm thinking that a new floor and lining of the walls is what's needed. Rebuilding is not an option.
Anyone done this?
Old Oct 24, 2016 | 01:08 PM
nomadicS2k's Avatar
You can coat the walls and floor with Vandex - its a tanking that will make it water-tight inside...should stop that!
PG
Old Oct 24, 2016 | 01:26 PM
S2K-Phil's Avatar
PG
thanks, have you used it before?
Old Oct 24, 2016 | 01:52 PM
nomadicS2k's Avatar
Originally Posted by S2K-Phil
PG
We were going to use this on our basement conversion - it was recommended by two builders - one who used it for garage conversions. We went for a full taking system with a plastic membrane in the end, but we have neighbours who did the same conversion as us and have used the product.
Old Oct 24, 2016 | 01:55 PM
S2K-Phil's Avatar
Cheers, do you know how hard wearing it is on the floor?
Old Oct 24, 2016 | 01:59 PM
nomadicS2k's Avatar
I would recommend putting a coat of hardener or epoxy over the top. The vandex is just a base
Old Oct 24, 2016 | 02:05 PM
S2K-Phil's Avatar
Okay and thanks again. Just need to work how much is needed as the adverts don't state covereage.
Old Oct 24, 2016 | 02:17 PM
S2K-Phil's Avatar
Actually, have just found the application is 4 kg·m[sup]2[/sup] so is going to cost a fortune for 4 walls and a floor.
Old Oct 24, 2016 | 10:34 PM
WinFreak's Avatar
Whatever you end up doing make sure there's enough ventilation in there
Old Oct 24, 2016 | 10:39 PM
unclefester's Avatar
^^^^ 100% this. Good airflow is essential to keep the damp at bay.
