Haynes Manual Translation
Was looking through my old emails lately and dropped on this little beauty. Thought i'd share. Enjoy:
HAYNES MANUAL - THE REAL MEANINGS
For those of us that have ever used a Haynes Manual in attempting home
maintenance of a car or motorbike. For those who haven't used a Haynes
Manual, these are the books aimed at those who want to fix their own
vehicles and which keep qualified mechanics in paid employment putting
things right afterwards. They are chock full of photos, diagrams and
step-by-step instructions which are obvious if you are a fully qualified
motor mechanic, but which are frighteningly sparse on detail for the average
Joe in the street who wants to change a set of spark plugs on a 1981 VW Polo
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips then beat repeatedly with hammer
anticlockwise. You do know which way is anticlockwise, don't you?
Haynes: Should remove easily.
Translation: Will be corroded into place ... clamp with adjustable wrench
then beat repeatedly with a hammer.
Haynes: Remove small retaining clip.
Translation: Take off 15 years of stubborn crud, it's there somewhere.
Haynes: This is a snug fit.
Translation: You will skin your knuckles! ... Clamp with adjustable wrench
then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Not a hope in hell matey! ... Clamp with adjustable wrench then
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start, now you
are looking at scary photos of the inside of a gearbox.
Haynes: Locate ...
Translation: This photo of a hex nut is the only clue we're giving you.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (catering size).
Haynes: Ease ...
Translation: Apply superhuman strength to ...
Haynes: Retain tiny spring...
Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to
dig out the bayonet part and remaining glass shards.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead
are throbbing then re-check the manual because what you are doing now cannot
be considered "lightly".
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating (simple).
Translation: Your Mum could do this... so how did you manage to botch it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low,
tiny, ikkle number... but you also thought that the wiring diagram was a map
of the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating (intermediate).
Translation: Make sure you won't need your car for a couple of days and that
your AA cover includes Home Start.
Translation: But Novas are easy to maintain right... right? So you think
three Nova spanners has got to be like a 'regular car' two spanner job.
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you pleb!
Haynes: Five spanner rating (expert).
Translation: OK - but don't expect us to ride it afterwards!!!
Translation #2: Don't ever carry your loved ones in it again and don't
mention it to your insurance company.
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at,
throw at the garage wall, then search for it in the dark corner of the
garage whilst muttering "bugger" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking
at, then declare in a loud knowing voice to your wife "Yep, as I thought,
it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much harder.
Once that sinking feeling in the pit of your stomach has subsided, you can
start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Locate securing bolt.
Translation: Remember that worrying noise when you drove along the A38 last
summer? That's where you'll find the securing bolt.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Remove drum retaining pin.
Translation: Break every screwdriver in your box.
Haynes: Using a suitable drift or pin-punch...
Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Everyday toolkit
Translation: Ensure you have an RAC Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Translation #2: Heat up until glowing red, if it still doesn't come undone
use a hacksaw.
Translation #3: Unless you have a blast furnace, don't bother. Clamp with
adjustable wrench then beat repeatedly with hammer.
Haynes: Index
Translation: List of all the things in the book bar the thing you want to
do!
Haynes: Remove oil filter using an oil filter chain wrench or length of
bicycle chain.
Translation: Stick a screwdriver through it and beat handle repeatedly with
a hammer.
Haynes: Replace old gasket with a new one.
Translation: I know I've got a tube of Krazy Glue around here somewhere.
Haynes: Grease well before refitting.
Translation: Spend an hour searching for your tub of grease before chancing
upon a bottle of washing-up liquid. Wipe some congealed washing up liquid
from the dispenser nozzle and use that since it's got a similar texture and
will probably get you to Halfords to buy some Castrol grease.
Haynes: See illustration for details
Translation: None of the illustrations notes will match the pictured
exploded, numbered parts. The unit illustrated is from a previous or variant
model. The actual location of the unit is never given.
Haynes: Drain off all fluids before removing cap.
Translation: Visit bathroom, spit on ground, remove baseball cap in order to
scratch head in perplexity.
Haynes: Top up fluids.
Translation: Drink 2 cans of beer and call out a mobile mechanic to undo the
damage.
For Added Haynes Fun, go to the first section "Safety First" and read the
bit about Hydrofluoric Acid. Would you really trust the advice of a book
that uses this form of understatement?
The best one I encountered was how to change a brake sensor in a Ford Fiesta
Popular Plus. The photo showing the location of the unit failed to mention
the crucial detail of whether the item was located in the engine compartment
or inside the car ..... and the helpful photo of what the thing looked like
didn't give the reader any clues!
THE CONDENSED HAYNES MANUAL
All makes and models post-2000
For a modern car chock full of electronics, all that's in the Haynes Manual
(aka "The Haynes Bumper Book of Jokes") is:
Routine Service: Take it to a main dealer and hand over a large amount of
cash.
Advanced Service: Open the bonnet. Decide all that stuff is far too scary.
Proceed with routine service (see above).
HAYNES GUIDE TO TOOLS OF THE TRADE
HAMMER: Originally employed as a weapon of war, the hammer is nowadays used
as a kind of divining rod to locate expensive parts not far from the object
we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on boxes
containing seats and motorcycle jackets.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their
holes until you die of old age, but it also works great for drilling
mounting holes just above the brake line that goes to the rear wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable motion,
and the more you attempt to influence its course, the more dismal your
future becomes.
MOLE-GRIPS: Used to round off bolt heads. If nothing else is available, they
can also be used to transfer intense welding heat to the palm of your hand.
OXYACETELENE TORCH: Used almost entirely for lighting various flammable
objects in your garage on fire. Also handy for igniting the grease inside a
brake-drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older cars and motorcycles, they
are now used mainly for impersonating that 9/16 or 1/2 socket you've been
searching for for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal
bar stock out of your hands so that it smacks you in the chest and flings
your beer across the room, splattering it against that freshly painted part
you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under
the workbench with the speed of light. Also removes fingerprint whorls and
hard-earned guitar callouses in about the time it takes you to say, "F...."
HYDRAULIC FLOOR JACK: Used for lowering car to the ground after you have
installed your new front disk brake setup, trapping the jack handle firmly
under the front wing (fender).
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a
hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbour to see if he has another hydraulic
floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog-doo off your boot.
BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten
times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile
strength of ground straps and brake lines you may have forgotten to
disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that
inexplicably has an accurately machined screwdriver tip on the end without
the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from
a car battery to the inside of your toolbox after determining that your
battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
INSPECTION LIGHT: The mechanic's own tanning booth. Sometimes called a drop
light, it is a good source of vitamin D, "the sunshine vitamin," which is
not otherwise found under cars at night. Health benefits aside, its main
purpose is to consume 40-watt light bulbs at about the same rate as 105-mm
howitzer shells during the Battle of the Bulge. More often dark than light,
its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; can also be used, as
the name implies, to round off Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a fossil-fuel
burning power plant 200 miles away and transforms it into compressed air
that travels by hose to a pneumatic impact wrench that grips rusty bolts
last tightened 30 years ago by someone in Dagenham, and rounds them off.
PRY (CROW) BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
Haynes: Locate ...
Haynes: Pry...
Haynes: Undo...
Haynes: Ease ...
Haynes: Lightly...
Haynes: Compress...
Haynes: Inspect...
use a hacksaw.
Haynes: Index
do!
bicycle chain.
a hammer.
damage.
cash.
future becomes.
you were drying.
hydraulic jack.
floor jack.
disconnect.
the handle.
I have read that before, but I still laughed out loud!
I remember having one for my first Civic.
Removing the glovebox and changing the clutch were both 3 spanner rating.... One of those jobs took me 5 mins and requires a screwdriver only.
The other doesn't.
The other doesn't.
How true!
I have a land rover, with the engine from a range rover. The Haynes manual for a Defender is close, but no cigar, as mine is a very early 110, so uses some Series 3 parts and some Defender parts AND some defender-esque parts, but with infuriating imperial thread sizes...
In my collection, I have the Haynes manual for a Defender, the Hyanes manual for a Range Rover of the correct vintage for the engine and gearbox (still not quite right as it doesn't cover SU carbs, merely Solex), the Land Rover 90/110 workshop manual, the Land Rover Range Rover Workshop Manual, the Land Rover Series III workshop manual, the Land Rover 90 Parts Catalogue and about 3 years' worth of LRO Magazine, with handy picture features on how to do the things that the others don't tell you.
On average, even when the operation on a particular part is described more or less correctly in 2 or more of these manuals, the torque settings are inevitably not the same.
There is, however, an answer. Call my mate Nibbs, whose answer is inevitably "just lop it off/open with an angle grinder, pull the bits out and you can have one of my spares out of the shipping container - I'll bring it down on Monday. Cheers mate!
Handily, there is no known manual for the S2000 other than the Honda one. This means that all though it's inevitably wrong, you spend 1/4 of the time looking things up and more time on the job in hand.
Some of those descriptions are eerily accurate!
I should imagine it took the Haynes guys weeks to work out one removes a Civic glovebox by squeezing it! Bit weird, that.
The ESM for the S2000 is great; it assumes one has a oil-stained diploma in monkeydom, which eliminates the foolhardy.
Modern Haynes Manuals devote chapters on the correct finger position on the bonnet release, since now everything else is too damned sophisticated; except modern car owners, who have spent their formative years going blind in front of a Playwithyourselfboxstation.
You should put a not safe for work warning on this. I nearly burst trying to suppress the laughter whilst reading this in a clients office.
I'm also having difficulty typong as I can't see through the tears.
It is SO true.
reving9kallday
Jan 22, 2009 11:03 AM
thing's never going back together!!!!!!
