Help on Oil Choice.
Old Dec 3, 2007 | 01:58 AM
billybiker's Avatar
Default Help on Oil Choice.
I've been doing regular oil changes on my Wife's BMW 5.35i (V8) using Mobil 1. The book calls for a 0w-X, where X stands for "the relevant figure, eg 30, 40 or 50"?? Providing the temperature stays above -15C then 10W-X is OK) So I guess a 0-40 is fine, and I'm going to ignore the bit about "long-life" oil as I do oil changes every 6K miles. Thing is, Mobil 1 at Halfords is over
Old Dec 3, 2007 | 03:36 AM
russellhq's Avatar
Try checking the codes the oil is manufactured to then look for an alternative with the same codes. Just a suggestion.
Old Dec 3, 2007 | 03:44 AM
aldfort's Avatar
Don't skimp on the oil. By a good quality branded oil preferabley synthetic of the correct grade.
BTW - if the engine will take a long life oil why are you not using it? It can often extend the time between changes to double that of a conventional oil. So it can work out cheaper.
does your wife's car have a "sevice meter" if it does and it's set up to run on longlife then I'd use it.
Old Dec 3, 2007 | 04:23 AM
Jel's Avatar
Jel
http://www.millersoils.net/1_Millers...UTO_RETAIL.htm
You can buy it from Motorsport / Motormania etc
Old Dec 3, 2007 | 06:31 AM
Opie Oils's Avatar
What year is your BMW?
The Mobil 1 is good stuff but you are paying over the odds for the brand name, especially from Halfords, the 0w-40 is also BMW LL01 approved.
A good BMW approved 5w-40 will be fine and there are plenty to choose from, Shell, Fuchs, Motul, Total, Millers and so on.
Cheers
Guy.
Old Dec 3, 2007 | 08:06 AM
billybiker's Avatar
Cheers
Guy.
[QUOTE]
It
Old Dec 3, 2007 | 08:09 AM
billybiker's Avatar
I think the long life oil is to allow you to stick to the BMW service intervals which are very long.
It does have a service indicator, yes.
Old Dec 3, 2007 | 08:33 AM
Opie Oils's Avatar
Im not a huge fan of longlife my self, oil should be changed annually at least if you talk to the chaps that build and design them.
Cheers
Guy.
Old Dec 5, 2007 | 01:28 AM
billybiker's Avatar
OK, that
Emil St-Hilaire
Feb 5, 2011 07:41 PM
jaxxx
Sep 8, 2010 04:41 AM
Lord-Jaffa
Nov 26, 2009 06:08 AM
