Welshman's Atom Build - Part 2
Went down to the factory today to see how they were getting on with the build.
A week ago it was like this:
Today it was like this:
So what had been done in the meantime.
First, fit the alloy fuel tank:
Second, assemble and fit the CF dash:
Third fit the discs and calipers:
Here's the nearside front
Add a reversing and fog light
Get a shiny new Civic Type R engine:
Some of the Honda engine loom is then removed and replaced by replaced by part of Ariel's own loom and then it's installed in the frame:
You'll notice that the stock exhaust manifold has been removed and it's replaced by this:
The standard gear linkage isn't used. Instead they use one from a Mazda:
Another view:
Drive shafts are connected up and the rest of the exhaust, including for the purposes of the IVA a Cat, is connected up:
Once the IVA is obtained the Cat Bypass Pipe replaces the Cat - on the right in the last photo - and is then just replaced for MOTs in due course.
Another view:
Rear Dampers are added:
Rear indicators/brake lights are added:
The radiator is installed in the front:
and the front panels:
Kelvin was installing the front dampers when I arrived:
The damper is connected at the front, then the spring is unwound at the front which allows the spring to be decompressed and connected at the rear - the compression is then reapplied.
You'll see that all the dampers are Bilsteins with adjustable compression and rebound on a scale of 1 to 10.
The build should be completed by the end of next week and then the car is taken to the DVLA/VOSA office in Exeter for the IVA which should occur the week after that so I am on track to take delivery in March assuming the weather improves.
