Wheel spacers
Old Jun 16, 2008 | 11:15 AM
MJ2k's Avatar
Default Wheel spacers
Hoping someone can help as the E60 forum is shocking!
Getting a 520d M-Sport shortly as a company car with optional M172 19" wheels (non run-flat so smoother than the 18").
Lots of the yanks have added 12mm spacers to the rear to make the wheels fill the arches more from a horizontal perspective & I admit it looks better.
My question is how this affects the handling by moving the rears out by this amount vs what was designed / engineered with the car. The yanks have all claimed it makes no difference, but given all their roads are straight and they claim amazing bhp increases on the S by giving it a wash I'm not feeling 100% confident.
Anyone with some pearls of wisdom they could share would be appreciated; I have seen spacers crop up on the forum a few times & whilst I understand what they 'do' I dont really graps what the risks may be.
Thanks
Matt
Old Jun 16, 2008 | 11:20 AM
Bibbs's Avatar
There are several different sorts.
Generally - they are okay as it's the same as running a wheel with a diff offset.
If you are running an offset non stock, it can chew wheel bearings. Usually if it's a few mm it'll not make a difference.
if it's just a small plate (under 5mm), you can get them on the stock wheel studs.
from 5mm to 10mm they usually supply longer studs.
The big ones (I used to run 25mm on my old MR2 to compensate for the wheels I bought as it needed a staggered offset) actually bolt to your hubs, and then have new bolts to mount your wheel to.
Old Jun 16, 2008 | 11:35 AM
Nick Graves's Avatar
I saw a BMW wheel catalogue, where the wheels came in soooo many offsets, it was stupid.
I think consulting BMW is the only safe bet.
I'd not deviate from OEM by more than about 5mm either.
Old Jun 16, 2008 | 11:37 AM
MJ2k's Avatar
Thanks Ben.
These require longer studs, which are pretty cheap.
Old Jun 16, 2008 | 11:39 AM
MJ2k's Avatar
even looking at 5's on the road there seem to be many variances; how else do you take wheels from 16-19" to fit on the same platform?!
Old Jun 16, 2008 | 11:43 AM
chilled's Avatar
Are these the wheels (the ones in the background)?
Old Jun 16, 2008 | 11:46 AM
MJ2k's Avatar
They are the ones, yes; PITA to clean I bet!
That's exactly it.
Especially when the platform covers such a ridiculous array of engine outputs, with the commansurate brake and tyre sizes required...
Old Jun 16, 2008 | 11:48 AM
MJ2k's Avatar
Maybe best to just play safe & stay as stock as OEM allows!
Old Jun 16, 2008 | 11:51 AM
Cheaper on the insurance, too.
Honestly, if it's bad enough for the one-size S2000, what's an E60 like?
I suppose it means you HAVE to buy from the BMW catalogue though. They ain't stupid!
