Alignment
Old Feb 2, 2006 | 07:35 AM
Teutonic Machine's Avatar
Default Alignment
I work in Statesville, and Everhart Honda said $150.00 to get the alignment done. Anybody know any places that do a good job for less than $150 near Statesville or Hickory? Also, I was wondering if anybody else's front tires were wearing on the inside much faster than the outside. It looks like my car has pretty aggressive negative camber, which seems to aid with turn-in in the corners.
Old Feb 2, 2006 | 03:16 PM
radred's Avatar
I recommend Caroll Aligning 1305 south Tryon. It's very close to downtown Charlotte. I have used them for my cars for more than 20 years. It's not a fancy place with electronic readouts, etc. Instead the alignment is done by experienced professionals. Be sure to tell them exactly what the car is doing driving wise and what you want. They align to spec in the book but will make changes as needed. I recommend a four wheel alignment to be sure everything is right. Two years ago hendrick honda aligned my S2000 after having to remove the transmission for a TSB, which required loosening some front suspension attachments. AFter their alignment the car was squirelly and would not track. After two attempts by Honda I took it to Carroll Aligning; problem solved.
Del
Gatsbee13
May 11, 2012 11:28 AM
IlleztImportz
May 16, 2009 06:09 AM
jeffbrig
South Florida
Jun 3, 2008 03:47 PM
Maveric
Jun 29, 2005 02:28 PM
dmck
Jun 15, 2005 09:21 AM
