Alittle Help if anyone can answer ..
Old Jan 28, 2009 | 08:33 PM
absolute_jdm's Avatar
Default Alittle Help if anyone can answer ..
..hey this might be a silly question .. but i just wanted to make sure .. how do you know if your LSD is working or not??? please? .. anyone?
Old Jan 29, 2009 | 03:22 AM
bubblehead's Avatar
I always judged by the tracers my hand made about 30 minutes into it.
Old Jan 29, 2009 | 05:37 AM
Saki GT's Avatar
go to a parking lot with some loose gravel, and make slow, tight turns on the gas, and listen for the inside tire to spin.
Old Jan 29, 2009 | 07:56 AM
hsuis2cool's Avatar
Not sure if this help
Go to an empty parking lot, Do a straight line burn out , and if you see 2 tire mark then I think your LSD is working , if you only see 1 tire mark, then you have an open diff.
Johnny
Old Jan 30, 2009 | 02:31 PM
ok ko0oL .. thanks for all the suggestions you guys! .. imma try those things suggested. ... also .. what is an "open Differential"?
Old Jan 30, 2009 | 02:44 PM
hsuis2cool's Avatar
Open Differential = non-Limited Slip Differential. The kind that you find on the average car
http://auto.howstuffworks.com/differential2.htm
Johnny
Old Jan 30, 2009 | 05:25 PM
mlc's Avatar
mlc
That is one of the best responses to a thread I have ever seen.
I Laughed My FA Off
Kevin
Old Jan 30, 2009 | 05:44 PM
O00oooh ok got cha .. Thanks Johny for the veryy helpfull link!
Old Jan 30, 2009 | 08:37 PM
whitemistress2k's Avatar
You can also jack the rear of the car up, put in 1st gear, and manually turn one wheel and the other one will turn the opposite way...
Old Jan 31, 2009 | 06:29 AM
heyy.. good idea!
