any comptech sc s2ks in the area?
If you run into any problems during the install email me or PM me and I might be able to help. I didnt install the SC but I did install a turbo so I learned a lot about the engine. The main problem you will run into is the crank pulley. When I was removing the SC it took three big guys and a breaker bar about 4 feet long to get the pulley off and that was after it had been removed once already. Its best if you can get a crank pulley tool from Honda because the tool holds the crank pulley in place so that you can put a ratchet in there with a bar and then pull the tools in opposite directions to loosen. Also its good to torque all the bolts to spec. The guy who installed my SC overtightened the bolts to hold on the SC bracket and it was damaged.
Well good luck.
Well good luck.
