Brake Upgrade
Old Sep 3, 2012 | 05:18 PM
Teds2kf20c's Avatar
Default Brake Upgrade
Had the car for about 2 months let the upgrades start!
I put new BFG Sport Comp 2 Tires all the way around.(Got rid of some terrible Hankook tires that came on it.)
Then Upgraded to Cross and drilled brakes all the way around with Adaptive One pads.
Time of Completion was about 45 mins easy install. After getting the set screws out and my rear caliper tool worked great.
Next Week its getting skunk2 lowering springs and Stainless Steel Brake Lines.
Old Sep 3, 2012 | 05:22 PM
YELLOW JACKET's Avatar
nice modd. gives it a sportier look not to mention improve braking. yellow ftw! where are you located?
Old Sep 3, 2012 | 05:31 PM
Teds2kf20c's Avatar
Doesn't stop to much shorter BUT the heat created went down by a few hundred degrees.
I work in Apex Live in Cary Play in Raleigh
Old Sep 3, 2012 | 05:34 PM
you get around man haha. have to come up after i get casper fixed.
Old Sep 3, 2012 | 05:38 PM
Teds2kf20c's Avatar
Every need a helping hand I'm always down to help a fellow S2k owner I'm a ASE cert tech. Hit me up I don't mind.
Old Sep 3, 2012 | 06:01 PM
awesome!
Old Sep 3, 2012 | 07:01 PM
Josh B's Avatar
Curious if you have any data proving those rotors alone reduced stopping distance? I have personally seen a few name brand drilled rotors fail and also have seen them increase stopping distance over solid rotors.
Sent from my PC36100 using Tapatalk 2
Old Sep 3, 2012 | 07:06 PM
Teds2kf20c's Avatar
I didn't check to see I was going for not warping rotors anymore I can do some brake tests and compare them with stock s2000 numbers.
But no I don't. I did do a temp test and them were loads cooler than before
Old Sep 3, 2012 | 07:48 PM
Josh B's Avatar
Were you having warping issues with OE quality Japanese rotors? What are your intended uses of your S?
Old Sep 3, 2012 | 08:10 PM
Teds2kf20c's Avatar
They were warped when I got it. Which I knew it needed brakes anyhow, got the cross and drilled for the same price as OE
