i need clutch alignment tool
Old Feb 21, 2010 | 07:28 PM
tacodorifto's Avatar
Default i need clutch alignment tool
does anyone have a clutch alignment tool that i can borrow or buy is so please let me know thanks
Old Feb 26, 2010 | 09:15 AM
SC_Highlander's Avatar
You don't need it. Get your eye level with the center of the flywheel and, visually, make sure the splines of clutch disc is centered around the pilot bearing in the flywheel. Make sure the bolts on the pressure place are loose enough to let you move the friction disc around. Once centered, crank down on the bolts. That's how I've done every clutch so far.
Old Feb 26, 2010 | 05:11 PM
well its to late i broke down and bought a tool for it. comes in monday. So engine goes in monday. thanks sc highlander
S2Timmy
Mar 16, 2010 04:34 PM
jdm.w
Oct 12, 2009 08:01 AM
BerlinaMOBster
May 25, 2009 12:30 PM
SPLNDID
Apr 6, 2008 08:30 PM
jack.tsu
Aug 16, 2007 10:22 PM
