Hey Triad members,
I'm getting a complete system from John and need help installing it. The system includes door speakers, sub and sub box, amps, and a HU with Ipod nano speed cable.
Can anyone help a newbie out? I want it done right the first time, so installation experience would be great.
If you need any help I can lend a hand I just finished a system in my S this past winter, with new door speakers and 2 amps with a sub. I did all the work myself and can help with somethings.
Hey guys, thanks a bunch. The system is two weeks out. S2kmanica81 and Saki GT thanks again. I will PM you guys once, I get the system in. Yes, I do have a garage to tear out the car properly.
hey did you guys, put that dynomat down also. Would you recommend it?
dynomat is expensive, I woudl check and see where all the rattles and noise is going to be first there might be ways of fixing it with it costing you an arm and a leg.
Dynomat is used as a sound proofing stuff, not so much as a rattle fixer. Dynomat if you decide to buy it would work well in the front, in the door speakers to drown out some sound from the road.
Dynomat is a bit expensive, but if you cut it into tiny sections rather than using the whole sheet or big chunks of it in spots it is quite effective. Just have to know where the troubled spots are and it should be fine.
