QUESTION FOR BRYAN
Old May 22, 2008 | 06:03 PM
black02S's Avatar
Default QUESTION FOR BRYAN
Having a problem with the S. When I accelerate or let of gas the rear end swerves like the wind is blowing me from side to side. I need to narrow this down and try and fix this tomorrow. Please help. If I can meet with someone who may know so they can drive my car and try and get this fixed. Please let me know. I am available all morning and afternoon tomorrow between 6am-3pm. I'm seriously begging for help.
P.S. This happened after driving through Paris Mt.
Rockey
Old May 22, 2008 | 06:50 PM
Yflyer's Avatar
did you check your tire pressures? good place to start.
good luck
Old May 22, 2008 | 07:03 PM
SC_Highlander's Avatar
Tire pressure is my first guess as well -- I'd bet on a low rear tire. I think your coilover install is relatively new as well, right? Might be a loose bolt or a bad shock -- just need to eliminate the low tire first. You're welcome to bring it by my office (near 385 and Roper Mtn Road) tomorrow.
Old May 22, 2008 | 07:20 PM
black02S's Avatar
Thanks I will give you a call tomorrow. Also what should the tire pressure be at cause I'm running 245's instead of the 225?
Old May 22, 2008 | 07:26 PM
30-32 cold
Old May 23, 2008 | 04:53 AM
Dressed2Kill's Avatar
Every time my car has done that I have had a low tire.
Old May 23, 2008 | 05:54 AM
black02S's Avatar
Did you tire look low they "look" fine!
Old May 23, 2008 | 06:04 AM
kuruma's Avatar
Yeah, I agree tire pressure or something loose with the new suspension!
Old May 23, 2008 | 07:36 AM
After driving it and taking a quick look, the right rear wheel has lots of side-to-side movement. I suspect a bad wheel bearing and damaged wheel hub. We're going to replace both in the morning at my place.
Old May 23, 2008 | 07:59 AM
kuruma's Avatar
Sounds like fun!
