Rebuilding engine...
Old Jan 3, 2009 | 01:12 AM
GyozA's Avatar
Thumbs up Rebuilding engine...
Alright so I need some advice on rebuilding the bottom end of the engine. Basically I just want it to run like it did stock. I spun a bearing a few months ago and the crankshaft is basically shot. Should I replace the full bottom end or just the bearings and the crankshaft??? I need this fixed ASAP. I'm set on ordering all the parts I need Monday.
Thanks in advance,
-Blake
Old Jan 3, 2009 | 03:40 AM
airgate's Avatar
SC_Highlander is an excellent source. If he doesn't post here, send him a quick PM.
Sorry to hear about your engine.
Old Jan 3, 2009 | 06:33 AM
SC_Highlander's Avatar
A new stock short block from honda is about $2500. You will spend over a grand on parts just for the crankshaft and bearings. That's assuming the journals in the block were not damaged by the spun bearing. I've done a rebuild that didn't go so well -- it only lasted about 6000 miles. Rather than deal with that again, I bought a complete motor out of a wrecked '05.
Old Jan 3, 2009 | 12:18 PM
GyozA's Avatar
Thanks guys... This makes me worry about buying used cars now. I found a short block on majestic honda for 2076. Are they a reputable dealer?
Here's the link. Majestic Honda
Old Jan 3, 2009 | 12:47 PM
Yes, but it will cost you a couple of hundred bucks shipping, and you will need a new headgasket , which is why I said $2500.
Old Jan 3, 2009 | 08:33 PM
busterpit23's Avatar
I've bought from them and they have been great.
You have PM
SHAKYBRAKE
Aug 14, 2020 06:16 PM
Delta_lima
Oct 10, 2016 10:52 AM
tkm_dave
Aug 31, 2014 11:30 AM
S2KSuzuka
May 16, 2008 01:09 PM
Chris3k2
Jul 22, 2007 06:56 PM
