What are the chances or passing emissions?
So I put my busted up cat. on my car Monday and the shop I took it to was closed for Memorial Day. I initially passed everything on the test but the visual inspection of the catalytic converter due to the test pipe being there instead. The guy told me to get the cat. put back on and pay the rest of the $6 to complete the inspection then everything should be fine. So on to the next part, one of the bolts to the cat fell off this morning and the CEL came back on. I rushed to Honda and bought a new bolt and spring and installed it. CEL is STILL on!!! The ECU has been reset and everything and it will not go off. I doubt my o2 sensor has been damaged by the bad cat. already so I suppose the cat. is that bad of condition. Ok so the thing is this... if I already passed everything else but the visual, shouldnt the only thing the guy should be looking for is a cat on the car and then send me on my way??? I was thinking of taping a picture down in the area where the CEL is and hoping for the best. I have to go to court in the morning right afterwards and I dont think theyre going to give me another continuance again.
Wow Mike.. sorry for the bad luck.
Where is S2kmaniac??? I would try to borrow his stock exhaust since he has an aftermarket, put it on, go pass inspection and bring it back.. that seems to be the easiest, quickest way to do it... IF you can get ahold of him. or anyone else for that matter that has a stock system lying around in thier garage.
I got a Cat I can let you borrow it if you think that will help you... My car right now doesn't have a cat and the o2 sensor is not connected, the light sometimes will come on but if I take the "back up" fuse or disconect the battery it will come off.. let me know... I'm in the Charlotte area...
Ok, so I got very lucky. My court date was yesterday but I got it continued till the 14th of June. Both options sound good... so I Civictos2000 I might would be interested in borrowing your cat for a day or so if thats cool I may opt for that. Ok so Intense, I have a few extra pieces for the o2 sim laying around... I thought about doing that last night. So if I throw one of those on there it should throw off the CEL? I may try that first and opt to borrow the cat should it not work. Thanks for everyones help.
I've use the spark plug anti-fouler ( I think thats how you call them..) as a mechanical 02 sim for about 15k miles with no problem...I used two to make sure..like the two that come in the same package, the long one and the short one together...
D.
D.
