Drunk dialing gets new meaning
Old Aug 9, 2006 | 07:41 AM
The Raptor's Avatar
Active Streak: 30 Days
Default Drunk dialing gets new meaning
If you attend sporting events, then this has probably happened to you: A fan or a group of fans seated near you, usually after a few too many beers, is using foul language and generally misbehaving. You look for an usher to voice a complaint, and none can be found. The Cincinnati Bengals have hit on one possible solution. The team announced Tuesday the creation of a hot line number that fans can call on their cellphones to report bad behavior. The number should be easy to remember
Old Aug 9, 2006 | 07:44 AM
UnkieTrunkie's Avatar
https://www.s2ki.com/forums/index.php?act=S...50#entry8295157
Old Aug 9, 2006 | 07:49 AM
The Raptor's Avatar
Originally Posted by 8D_In_Trunk,Aug 9 2006, 08:44 AM
Old Aug 9, 2006 | 09:24 AM
CrazyCracker82's Avatar
don't make me the call the ruckus line on you two
Old Aug 9, 2006 | 10:53 AM
Old Aug 9, 2006 | 11:35 AM
PopTarts's Avatar
Old Aug 9, 2006 | 12:00 PM
O-turn's Avatar
[QUOTE=The Raptor,Aug 9 2006, 11:41 AM] If you attend sporting events, then this has probably happened to you: A fan or a group of fans seated near you, usually after a few too many beers, is using foul language and generally misbehaving. You look for an usher to voice a complaint, and none can be found. The Cincinnati Bengals have hit on one possible solution. The team announced Tuesday the creation of a hot line number that fans can call on their cellphones to report bad behavior. The number should be easy to remember
Old Aug 9, 2006 | 12:43 PM
Old Aug 9, 2006 | 01:48 PM
nakdboardr's Avatar
Old Aug 9, 2006 | 01:54 PM
