How to Make Free iPhone Ringtones with iTunes
Old Jun 17, 2010 | 11:43 PM
borrysa's Avatar
Default How to Make Free iPhone Ringtones with iTunes
Those good, old days when creating an iPhone ringtone was as easy as renaming a song in your iTunes library to a ".m4r" extension and then syncing it back with your iPhone will never come back with the release of iTunes 8 – which brought with it Genius Playlists.
Keep in mind that iTunes will allow you to create a ringtone from a song downloaded through the iTunes Music Store, but those ringtones come with fees. No one likes fees. Follow this guide, creating iPhone ringtones for free with iTunes comes back again. To create simple, free iPhone ringtones from your iTunes library, the following step-by-step guide will help you out:
Note: * This process works with MP3, ACC, and AIFF files. * Only DRM-free songs can be used with this ringtone creation process. * Any song downloaded from iTunes Music Store will have DRM (Digital Rights Management), so don't use those songs. * Any song ripped from a CD or downloaded from DRM-free sources (P2P, Amazon, your friend) will work just fine. If you want use DRM protection resource, you should first remove DRM protection from iTunes.
Step 1.
Launch iTunes.
Step 2.
Find the song you'd like to turn in to a ringtone.
Step 3.
Right click on the song and select "Get Info".
Step 4.
Hit the "Options" tab and check both the "Start Time" and "End Time" boxes.
Step 5.
Specify what time interval you'd like to use as your ringtone clip , then click "OK"(Make sure your ringtone is 30 seconds or less!!).
Step 6.
Click on "Advanced" in your menu bar and select "Create AAC Version" or "Create Apple Lossless Version" (Make sure your iTunes "Import Settings" are set to "AAC" or "Apple Lossless" and not "MP3").
Step 7.
A duplicate copy of your song will appear in iTunes – this new song will have the same filename but shorter "Time". Go back to the original song and uncheck those "Start Time" and "End Time" boxes.
Step 8.
Drag the duplicate song to your Desktop, once the duplicate song is copied to your Desktop, delete the duplicate file in iTunes.
Step 9.
On your Desktop, rename the file with the ".m4r" file extension – Use the new extension, this turns your song file into an iPhone ringtone file.
Now be named "songname.m4r".
Step 10.
Drag the newly renamed .m4r (songname.m4r) file back into iTunes.
Step 11.
Drag the file over the "Library" column and release when "Library" becomes highlighted. (You have to delete the duplicate song file otherwise iTunes won't import your new .m4r file ).
Step 12.
You should see your new ringtone under "Ringtones" in iTunes.
Step 13.
Sync your iPhone to get jiggy with your new free iPhone ringtones!
Information from: http://iphone.ringtone-make.com/
Old Jun 18, 2010 | 03:43 AM
zdave87's Avatar
Member
There's an app for that.
Old Jun 18, 2010 | 07:14 AM
KeithM's Avatar
Old Jun 18, 2010 | 10:38 AM
UnkieTrunkie's Avatar
Show us your tits
Old Jun 18, 2010 | 06:22 PM
CrazyCracker82's Avatar
Old Jun 18, 2010 | 06:28 PM
zzziippyyy's Avatar
ya its called app
Old Jun 21, 2010 | 01:09 PM
Have we seen tits yet?
Old Jun 21, 2010 | 01:46 PM
zzziippyyy's Avatar
Negative so still thread fail!
Old Jun 21, 2010 | 01:49 PM
Old Jun 21, 2010 | 02:08 PM
KeithM's Avatar
I saw boobs once
