Dragon Tech Day
Old Feb 7, 2015 | 07:09 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Default Dragon Tech Day
I'll be doing my usual tech days on Thursday and Friday at 7am-10am. Usual spot, working by the dent guy in front of the Wildwood Grill.
Paid services include Valve adjustments and my GenX TCT(in sig below). Both services are discounted at RTD, the only event or venue in which I do so. Valve adjustment will have particular importance in regards to 2006-2009 S2000s, see here:
https://www.s2ki.com/...wners-dbw-cars/
Free services for registered RTD attendees include axle nut TSB, clutch adjustments, throttle adjustments, soft top instruction and filing, noise diagnosing, general inquiries, etc.
TCT only customers can be done at any time throughout the week and weekend.
If you would like the axle nut re-torque (axle nut TSB), please have your rear centercaps removed. AP2 V3 wheels will need to be removed to get the centercap out, as well as some aftermarket wheels.
Please let me know if you would like a spot on Thurs or Friday. Please post and/or PM me with the topic title "dragon tech day" to get on the list.
Schedule:
Wednesday:
-7am BD valve adjustment (WED is a maybe)
Thursday:
-7am CenturionS2k Valve Adjustment, antsb, soft top file
-7am Batguano, valve adjust, antsb, tri
Friday:
-7am CitadelBlue, Valve Adjustment & TCT, tri, antsb
-7am zdave87 va,tct,plugs
-7:30am poorshoeless, VA, TCT, antsb (needs to roll 8:30am)
-7:30am pwrinxs tri, latches
wait list:
florian
GenX TCT:
JFUSION
Habitforming
jvf1
LDubz735
driveaholic
victoryimminent
//steve\\
Old Feb 7, 2015 | 07:16 AM
CenturionS2K's Avatar
Thursday. 7am: VA, axle nut TSB, and soft top instruction and filing. Thanks
Old Feb 7, 2015 | 07:19 AM
zeroptzero's Avatar
Bill, can you put me down for a TCT on Friday 7am - first appointment seeing as no one is on the list yet. I think I have a drive booked for 8:30 am.
Here is my issue. My current TCT is very quiet while the engine is running, but I get a rattlesnake sound on first start up , it is like the chain is rubbing on the guides for a couple of seconds until oil gets running through it or something. If you think your TCT will help with this I'm good for a new one, but if you think this is a normal sound then let me know either way.
Thanks , look forward to meeting either way - Joey
Billman250's Avatar
Top Answer: 1
Centurion, let me know the time of your first planned drive of the day, and I'll adjust so you are ready for it...will do both cars at 7, with priority to the days/attendies schedule
Old Feb 7, 2015 | 07:21 AM
Billman250's Avatar
Top Answer: 1
Joey I'll put you down, and yes it will cure that noise for life.
Old Feb 7, 2015 | 07:22 AM
zeroptzero's Avatar
Awesome ! , I'm good with this , much appreciated
Old Feb 7, 2015 | 07:25 AM
CitadelBlue's Avatar
Bill, add axle nut torque, clutch and throttle adjustment.
And would you move me to Friday vs Thursday. Thanks
Old Feb 7, 2015 | 07:54 AM
zdave87's Avatar
Member
All of the above. Friday at 8am? I'm guessing it'll take you 1 hour for CitadelBlue & JFUSION. If it takes longer than 1 hour, just put me down for the first approx time slot you have open.
Old Feb 7, 2015 | 08:11 AM
batguano's Avatar
Bill, Glad t see you are coming.
I would like axle nut adj,throttle and clutch.
Anytime is good for me.
Old Feb 7, 2015 | 08:20 AM
jvf1's Avatar
Bill:
I would like a TCT only please.
You can squeeze me in whenever is best for you, but I'll be doing lots of driving so an early morning or an evening would be best for me.
