Alignment Specs
Old Oct 30, 2006 | 04:17 PM
Willie Gee's Avatar
Default Alignment Specs
Lately I've been getting a few PMs regarding alignment specs, so I figured I'd open up a thread about it. If you can: list your tire size, suspension mods, springs, coilovers, sway bars and your alignment specs. If you AutoX or track your car let us know that as well.
I'll start:
KW V3 coilovers, 32 mm front Cusco Bar.
225 fronts and 255 rears Potenza S03 pole positions.
Alignment:
Front:
Camber: -1.7
Caster: 7.2
Toe: 0
Rear:
Camber: -2.7
Toe: .23
Learning to AutoX, love to drive canyon roads (but haven't found one in FL---- yet)
Car handles better than the driver.
Old Oct 30, 2006 | 04:23 PM
jphish's Avatar
What is an alignment? Is that a new mod? How come I have never heard of this?
Koni Yellow shocks with Espelir ASD springs on the bottom perch. I raised my car to the top perch and haven't gotten another alignment yet.
Front:
Left:
Camber: -.6
Castor: 6.4
Toe: -.04
Right:
Camber: -.6
Castor: 6.4
Toe: -.04
Rear:
Left:
Camber: -1.7
Toe: .28
Right:
Camber: -1.7
Toe: .22
Old Oct 30, 2006 | 05:23 PM
fernies04s2k's Avatar
Front:
Left:
Camber: -.6
Castor: 6.9
Toe: -.00
Right:
Camber: -.6
Castor: 6.6
Toe: -.00
Rear:
Left:
Camber: -3.5
Toe: .16
Right:
Camber: -3.4
Toe: .13
Old Oct 30, 2006 | 06:20 PM
Iceman1's Avatar
Originally Posted by fernies04s2k,Oct 30 2006, 09:23 PM
Rear:
Left:
Camber: -3.5
Toe: .16
Right:
Camber: -3.4
Toe: .13
and u got that camber with the stock suspension?
Old Oct 30, 2006 | 06:27 PM
rijowysock's Avatar
i have -4.7* camber in rear on tein flex... -3.4* in front
i love it :-D
stock camber stuff tho. just aftermarket susp
Old Oct 30, 2006 | 06:33 PM
negcamber's Avatar
Koni + Espilar, Comptech Adj Bar .v1 (full stiff)
225 fronts and 245 rears Hankook RS2
Alignment:
Front:
Camber: -2.0
Caster: 6.0
Toe: 0
Rear:
Camber: -3.0
Toe: .25 in
Old Oct 31, 2006 | 06:57 AM
Iceman1's Avatar
whats the max rear camber you can get on a stock AP1 suspension?
Old Oct 31, 2006 | 07:35 AM
negcamber's Avatar
I've seen 2.25...I would think 2.5 would be pretty close to the max without lowering.
Old Oct 31, 2006 | 09:20 AM
Bandiscoot's Avatar
alignment? yep ... i got one it does well in wearing my tires out (my driving style has NOTHING to do with it ... heh, right)
I don't have the specs ... but, i 'split' the specs between the US and Euro.
I have yet to fully test it out ... no autoX on it yet. Just back roads and the Dragon. So far I'm loving it ... just don't know the 'limits' of it especially with transitions and weight transfer. When it does break laterally it is 'soft' but requires a brisk correction to avoid full lock (not a panic move though ... just gotta be willing to be aggressive when steering into it)
EDIT: i'm on Espilir springs btw
Old Oct 31, 2006 | 09:48 AM
GranPrix's Avatar
Stock AP2:
Front:
Left:
Camber: -.4
Castor: 8.1
Toe: -.06
Right:
Camber: -.5
Castor: 8.5
Toe: -.00
Rear:
Left:
Camber: -1.4
Toe: .11
Right:
Camber: -1.3
Toe: .26
