Any reason to not to do a 1'' drop?
Old Feb 20, 2006 | 12:36 PM
Kyushin's Avatar
Banned
Default Any reason to not to do a 1'' drop?
Im curious as to if there are any negative side effects of lowering the car 1''. please post input and impressions. Im gonna be doin a 1'' drop with Eibach springs from Tirerack wiht 18'' wheels.
Old Feb 20, 2006 | 01:32 PM
Sub-Zero's Avatar
I am doing the same with 19s. I don't think there will be a camber problem with just 1 in but a camber kit is cheap.
Old Feb 20, 2006 | 02:31 PM
PrimoGen's Avatar
you will have camber wear and you will chew through tires. An alignment can only take you so far back to spec and even though they do make a camber kit for the fronts it is really cheap and they do not have anything for the rears.
I say drop it because I am lowered and inch and a half myself. But be prepared to buy tires more often when you do drop it.
Also a 1 inch is less severe than say a 1.5 or 2 but you will have to be more careful on steep drives and speed bumps because you will rubb and scrape too
My .02
Old Feb 20, 2006 | 03:09 PM
DrEvil's Avatar
You will be mad that you didn't lower it more.
Old Feb 20, 2006 | 03:21 PM
Kyushin's Avatar
Banned
Think ill really need a camber kit being that we are fully adjustable, and if i really do need a kit, whree can i find a good one?
Old Feb 20, 2006 | 03:23 PM
BigRedsS2's Avatar
I think a 1inch drop would be okay, because the car already has an adjustabnle camber kit on it. However, I think you will go through tires faster. I'm doing at least a 1 inch drop as soon as I get the extra money.
Old Feb 20, 2006 | 04:49 PM
Raven628's Avatar
Since you are looking at Eibach springs you might want to look at the Ground Control coilover. They use Eibach springs and you can adjust them when needed.
I had them on my last car, 03 CL with the stock struts and then with KONI yellows. Both set ups were a smooth ride and I just dropted 1 inch.
Just some options for yah
Old Feb 20, 2006 | 08:27 PM
ArchAngel2K's Avatar
I had 18's and i hated them. sure they look nice but still didnt like them. i gave them to balboa and he said they rub........ sure he gave the car a 2 inch drop but still i wouldnt.
Old Feb 20, 2006 | 08:35 PM
rijowysock's Avatar
from the guys whos been slammed since well forever.
lowering the car does not cause crazy tire wear.
TOE causes crazy tire wear, a correct alignment will eliminate toe and you will still have camber.
our cars have dual wishbone on all 4 corners which LOVES camber. eats it up like a hobo with a ham sandwich.
given extreme camber such as.... -2.5+++ will cause "camber" wear.. but @ 1" drop you can correct that fine.
just make sure to ALIGN after the springs settle.. that way its actually doing something and DO NOT JACK the car up after springs settle and before you go to an alignment place.. make sure they drive it up and do not jack it up..
most people. put on springs.. and either dont get an alignment or they go right away.. or they wait and the shop jacks it up to fit on the lift and ruins everything. waste of an alignment.
BTW 1" drop wont look very good but its actually an improvment on handling.. anything more then 1" actually hurts handling.
carlton, the S & 19's is going to be alot of rotaional mass to turn but oh well ur torbo'd. i was always 19" guy until i got the S and realized i need to settle for 18..
also just a spring is going to drop the car, but its not gonna handle like god. you need shocks valved similarly to the spring rate, also aftermarket shocks will not bust with the extreme pressure being put on them by the piston being further down into the shock body.
for the ETC, so on and so forth.. pm me.. the whole "tire wear" is BS.. so dont make your drop based on that. ALSO rubbing out and scraping should be less with a firmer Spring.. because the ride doesnt "bounce" when going over objects.. the only thing your going to hit is something taller than the actual car.
Old Feb 20, 2006 | 08:42 PM
rijowysock's Avatar
Question
.::MISSING CONTENT BECAUSE ROB IS A DUMB AZZ!!!::..
just remember front bumpers and strakes are cheap.. so dont worry about em.
