Calling all SPA yellows
I have a rear ap2 bumper i would like to switch back to an ap1. Bumper is painted spa yellow by autoway collision center. Matching is not perfect but still is good. Just two weeks ago i got into a fender bender and the ap2 bumper now has a crack on the left of the license plate. If anybody wants to switch to ap2, heres your chance. Crack is not visible unless you are close. Let me know if you are interested and we will work out a deal. Thanks.
Wow, I thought someone would jump on this. Where are you located? I might be interested in a trade if you can't find anyone else. My bumper isn't perfect though, some lady backed into my car before I got it
I took pictures so you can see what it looks like. There's a slight crease behind the tire on the driver's side and a little touchup paint. It also pulled the bumper down a little, leaving a small gap between the fender and bumper (might be fixable with an adjustment, I have no idea). Anyway, here are the pics.
Edit: Incase you can't tell, the crease is an inch or 2 from the top of the bumper (knowing where to look you should be able to see it). There's touchup paint on the edge of the bumper by the tire, and a spot directly below the crease and about 3 inches to the right of the other touchup spot. Hope that helps, did the best I could, my camera sucks!
I took pictures so you can see what it looks like. There's a slight crease behind the tire on the driver's side and a little touchup paint. It also pulled the bumper down a little, leaving a small gap between the fender and bumper (might be fixable with an adjustment, I have no idea). Anyway, here are the pics.Edit: Incase you can't tell, the crease is an inch or 2 from the top of the bumper (knowing where to look you should be able to see it). There's touchup paint on the edge of the bumper by the tire, and a spot directly below the crease and about 3 inches to the right of the other touchup spot. Hope that helps, did the best I could, my camera sucks!
txs2knoah
Dec 14, 2008 09:02 PM
