Car sagging PLEASE HELP
Old Dec 31, 2006 | 12:21 PM
cps_protection's Avatar
Default Car sagging PLEASE HELP
I have a problem I just replaced my springs in my car because the driver side of the car was sagging 1 inch lower than the passenger side. When I bought it to the mechanic I was told that the springs over time will sag. I called Honda and spoke to two of there mechanics and they said the same thing the other guy said I was also told that there is a service bulletin about driver side sag for US Hondas.
Now the problem, the new springs are in and the car is still sagging when I bought the car I asked for a carfax from the dealer and never got it when I looked it up myself I found the car was in a accident. I really don
Old Dec 31, 2006 | 01:03 PM
PrimoGen's Avatar
Question
sounds like its time for new shocks to make sure that is not the problem. other than that it could be the frame or the A-arms or the axel....alot of things can affect the stance
If you found out the car was in an accidient, why did you buy it?? was it a good price? Not flamming you, but if i found out my car had the damage it had before i bought it, I never would have.
How extensive was the accident? did the car fax tell you what kind of damge was repaired on the car?
Old Dec 31, 2006 | 01:29 PM
It was my bad choice I bought the car then ran the carfax after the fact I would have never would bought the car if I knew it was in a accident and like I said before I asked for a carfax when I was there and the dealer said he would get it. Negotiations started again and I lost track the price was fair a little less than book. I looked up to see if anyone else had this problem and came across a post explaining it could be the controller are how can I check that??
Old Dec 31, 2006 | 01:53 PM
RadioZero's Avatar
assuming you're talking about the control arm? if so, you need to be under the car and do a visual on the control arms and possibly take measurements with a tape measure.
simple question, did you check your tire pressures? is your alignment good? worn bushing could cause sagging, if your alignment is good, then your bushing should be good.
Old Dec 31, 2006 | 02:52 PM
S2KPUDDYDAD's Avatar
I am certain springs are not the problem. The chances of a spring sagging in a car that is just a few years old is unlikely.
Do not pass go do not scratch your head anymore, get the car to a VERY GOOD alignment shop, not just any
Old Jan 1, 2007 | 06:39 AM
Thanks for the help guys Iv got a better idea on how to figure out the problem I will update you when I find the problem
Old Jan 1, 2007 | 01:50 PM
vvs's Avatar
vvs
Yeah, you need to get this up on a rack. You may want to consider a body shop that has a alingment rack and frame rack. Sounds like repairs were not done right.
If all else fails, call the State Attorney's consumer help line and they can direct you elsewhere.
James
SiReal
Sep 15, 2010 01:23 PM
Mark355
Mar 28, 2010 05:42 PM
RL1924
19
Apr 29, 2009 06:23 PM
apxking
Dec 11, 2008 01:42 PM
THAT K1D
Apr 9, 2008 06:46 AM
