cuts off at idle
What could be the issue? I have an 04 and it cuts off at idle. Spark plugs have already been replaced. I don't know what else could be wrong.
Have you cleaned the IAC it's close to the throttle body research IAC and you'll find it
Sent from my SCH-I545 using Tapatalk 4 |
Had you disconnected the battery for anything? After I did that to change the battery mine would stall like the first four times if went to idle, car learns where it needs to idle after some time
Couldn't really find anything that gives clear instructions on how to take apart the IAC. Didn't disco the battery for anything.
Well I did more research and it was a lot more work than what I thought. Will update in a few days. Thanks
Did you recently have the clutch changed? Sometimes the Knock sensor get hit and it's very sensitive and fails as a result. But you will have a clear indication of this with a check engine light.
IAC cleaned and so far no issues thanks
Awesome that's great
