cuts off at idle
Had you disconnected the battery for anything? After I did that to change the battery mine would stall like the first four times if went to idle, car learns where it needs to idle after some time
Did you recently have the clutch changed? Sometimes the Knock sensor get hit and it's very sensitive and fails as a result. But you will have a clear indication of this with a check engine light.
