Hit Curb
Old Sep 2, 2007 | 03:18 PM
FIdreaming's Avatar
Default Hit Curb
Well I hit a curb today going <10MPH with the front driver side wheel. I bent the wheel out of round so...
Is there anyone out there who has 1 FRONT version 1 AP2 wheel?!!! They could part with?? Just name your price!!
Thanks
Old Sep 2, 2007 | 05:23 PM
SLO S2k's Avatar
I have a AP1 front with curb rash. I don't know which version it is though.....
$25 plus shipping and paypal fees
Old Sep 2, 2007 | 05:30 PM
FIdreaming's Avatar
[QUOTE=SLO S2k,Sep 2 2007, 05:23 PM] I have a AP1 front with curb rash.
Old Sep 2, 2007 | 06:00 PM
SLO S2k's Avatar
oooppsss my bad didn't read. Bump for you anyway
Old Sep 2, 2007 | 07:32 PM
negcamber's Avatar
Not sure how this site sells them so cheap...not sure if they are some Chinese knock off or what. But:
http://shop.wheelsrims.net/search.html?off...ype=alloy_wheel
Old Sep 3, 2007 | 02:37 AM
RadioZero's Avatar
if you bent the wheel, you better check the control arm also. i would have the alignment checked and make sure the guy looks at the control arms and tie rod.
Old Sep 3, 2007 | 06:06 AM
negcamber's Avatar
Good point...our a-arms tend to crack (they don't really bend). Take a close look.
Old Sep 3, 2007 | 12:07 PM
FIdreaming's Avatar
Thanks for the heads up, here are some pictures.
As you can see it is only slightly bent, when I spin the wheel it wobbles pretty good. the car pulled to the right very bad on the drive home. So I should also look for..
1. A-arm damage
2. Tie rod damage
any shop could spot this right?
Old Sep 3, 2007 | 12:50 PM
RadioZero's Avatar
ouch.... in addition, you should check the hub and knuckle assembly. these are the parts that the wheel and brake rotor attach to, you can bend the hub and it will eventually cause the wheel bearing to go bad.
edited for clarification: even if your car gets an alignment and it feels good, if the hub is bent the wheel bearing will still eventually fail.
make sure you look at the frame where the A arms attach to make sure there are no bent bolts or bent mounting points.
sucks to go through this but based on your car pulling to the right, your alignment is screwed at the very least. hopefully, it's not worse than that. sad to say but sometimes the little things can be expensive to fix.
Old Sep 3, 2007 | 01:33 PM
SLO S2k's Avatar
Is the tire flat also? If so take it to a tire facility to make sure the sidewall isn't damaged also.
