Hondata Gasket
Old Aug 15, 2006 | 04:27 PM
FIdreaming's Avatar
Default Hondata Gasket
Im going to buy the hondata gasket, and have 2nerworks do the install. my question is, Should I also install the mugen thermostat and fan switch? or will the hondata gasket alone be just fine? seems like i read somewhere that you should also install the thermostat and fan switch when you do the hondata gasket.
Thanks
-FI
Old Aug 15, 2006 | 05:24 PM
negcamber's Avatar
Doing the thermostat and fan switch is not necessary, but is easy as long as you already have the intake manifold off the car (the thermostat sits under the intake manifold).
Old Aug 15, 2006 | 06:19 PM
Willie Gee's Avatar
I'd do all three. You won't (shouldn't) have your manifold off very often. Just get the job done then.
Old Aug 16, 2006 | 05:07 AM
Chiung's Avatar
but if $ is an issue, wait on the fan switch - it can be installed anytime with a 24 mm deep socket and ratchet. You don't need to take anything off to get to it.
Old Aug 16, 2006 | 09:29 AM
FIdreaming's Avatar
Ok thanks for the advice
mattie170
Aug 20, 2013 08:16 AM
1.8TsBLOW
Nov 8, 2006 04:47 PM
mice
Apr 25, 2005 08:56 PM
s2khondaimport
Jan 6, 2005 07:11 AM
Russ
South Florida
Jun 23, 2004 09:42 AM
