Need Help with a DCI-2 and my Alpine Deck
Old Mar 24, 2008 | 03:43 PM
1outs2kisback's Avatar
Default Need Help with a DCI-2 and my Alpine Deck
I just got a DCI-2 for my aftermarket Alpine cda-9825. The unit I got was used and pre wired for an Alpine deck, wiring looks good, and head unit plays fine. I pluged in my harness and no good, head unit played no dash controls? The only thing that worked was the mute button? I didnt wire the speed sensor???? and I didnt have that 3.5mm stero jack plug in the back of my head unit, I dont have a plug for it, so it was not plugged? The little toggles looked to be in the right places as per wiring diagram. Any ideas what could be wrong? or how I might re set my DCI-2 or make sure it's good? Let me know if you guys have had any problems like this? Thanks, Martin
Old Mar 24, 2008 | 04:27 PM
jphish's Avatar
If you don't get any responses here, try posting in the Electronics Forum
I've never heard of this. I would suggest taking a closer look at the wiring again.
Old Mar 24, 2008 | 05:26 PM
dangators05's Avatar
Electronics forum FTW, those guys know EVERYTHING!!!!
Old Mar 24, 2008 | 06:59 PM
S2KSuzuka's Avatar
That plug is the key to it working, that's where it sends the signals. the mute funtion is hard wired in so it works. you have two choices
1. trade your radio back for one with the jack in the back for steering wheel controls (best option)
2. get the DCI that uses an infra red emitter to work. that emmitter has to be placed around the area of the radio that senses IR. I personally don't like the look of that one, and if the top is down and the radio door is open the controls may not work
Hope that helps
Mitch
Old Mar 24, 2008 | 07:18 PM
Yea that stereo plug is needed... Wonder if I can use one of these Alpine KCA-121B Ai-NET/RCA Audio line adapter cable plugs that goes into the cd changer port? It would allow me to plug in the 3.5mm stereo plug? Might work, going to try it, if not I get new head unit. Thanks guys anyone else chime in!
Old Mar 25, 2008 | 01:14 AM
S2KSuzuka's Avatar
using an adapter will not work, that jack on the back is specifically for IR input, nothing else will work. upgrade your radio and you will be good to go
Old Mar 25, 2008 | 08:11 AM
Dave-ROR's Avatar
The guys above are 100% correct.
Old Mar 25, 2008 | 02:10 PM
BORT617's Avatar
i just got my KCA-121B in the mail if you want to try it, but i am pretty sure those guys are correct about the 3.5 being needed. if you decide you don't want the dci let me know
Old Mar 26, 2008 | 02:00 PM
Bought a new deck alpine cda 9883. Should be good to go.....Thanks guys
Old Mar 26, 2008 | 02:20 PM
S2KSuzuka's Avatar
anytime,
good luck
globallyoff
Apr 22, 2021 08:19 AM
LiQUiD iCE
Aug 18, 2018 07:55 PM
Bracam
Aug 21, 2012 02:27 PM
KeithD
Apr 4, 2007 01:19 PM
ratfink
Dec 29, 2006 09:49 AM
