NEED A LITTLE HELP, PLEASE
Originally Posted by #1turbos2k,Jan 3 2011, 01:37 AM
is the only way to check if a piston ring is bad is to remove the piston or just by doing the compression test i know that the piston rings are good ? anyone ?
alright, we replaced the head gasket, took the head to a local machine shop and replaced the valve seals and had the head re-surfaced. i installed it back in the car and the S turned on wonderful and no more smoke....but now i have another problem that i dont understand why is happening all i did was head work and gasket replacement, NOW the v-tech doesnt want to kick in or turn on. i replaced the gasket on the v-tech so the filter is nice and clean. why doesnt the v-tech work? any ideas or suggestions....
how do i check the oil pressure on a stock s2k....?
You seem like you know what your doing to have done all this work your self... but just fyi... its VTEC... V-TECH is a phone and toy product... im sorry but i couldn't help it.. it drives me NUTS when i read that... on a lighter note.. did u make sure the it was plugged in? lol is there a check engine light?
Get a multimeter and check the connections at the harness for the solenoid. I don't have the resistance specs but someone else may.
Definitely worth every penny to have a Helms manual with something like this
Good luck in figuring it out. I'm really relieved the smoking stopped
I dont have a helm book but I sure have the repair manual specific for the S.
Thanks for the tip.
