oil changes in orlando!
Old Jan 3, 2007 | 05:03 AM
FL05S2K's Avatar
Default oil changes in orlando!
Where do the orlando folks get there oil changes at? I don't have the tools or expertise to do it myself and since scott is no longer here i cannot go to him for my oil changes...any suggestions?
Old Jan 3, 2007 | 05:19 AM
RadioZero's Avatar
people seem to be using 1st class automotive lately. they are getting good reviews.
Old Jan 3, 2007 | 05:41 AM
calaceyfl's Avatar
Def. 1st class auto.
Old Jan 3, 2007 | 05:55 AM
FL05S2K's Avatar
i assume they are appt only...sucks they aren't around on the weekends bcs it is going to be hard for me to get there before work!
Old Jan 3, 2007 | 07:43 AM
jphish's Avatar
DIY. It isn't difficult and the tools required are not expensive.
Old Jan 3, 2007 | 08:21 AM
Fla S2000 fixer's Avatar
Hi, this is Oster with First Class Automotive. All you need to do is call me, let me know what day is best for you, and i can do it early or late. As long as its a good day for both our schedules.
I do it for other customers, and dont mind helping you out either. For anone else that might read this thread, this is for minor jobs only
Call and ask for me.
Oster
Old Jan 3, 2007 | 09:39 AM
wildcardtrd's Avatar
Tools required:
2 ramps
1 jackstand (for safety)
17mm wrench or socket
funnel
drain pan
Drive up ramps. Turn off car, leave in gear, set ebrake. Place jackstand under subframe. Place drainpan under oil pan. Remove drain bolt from oil pan. Open oil filler cap. Remove oil filter from side of block (I use K&N oil fiters, they have a nice bolt head on them that makes removal with an adjustable wrench very, very easy). Coat o-ring of new oil filter with oil, to prevent adhesion to the engine block. Fill 1/2 of oil filter with oil. Once oil has stopped draining from the car, replace the oil pan drain bolt. Install new oil filter by spinning it on until it just touches the block (stops free spinning), then, by hand, tighten another 3/4 to full turn, or as much as you can by hand w/o too much torque. Insert funnel into oil filler hole. Fill w/ recommended oil type and amount. Remove funnel, replace cap. Pull drain pan from under car, recycle oil. Remove jackstand, roll car down ramps. done. Elapsed time, 20 minutes.
Old Jan 4, 2007 | 05:20 PM
Thats a good investment if you dont have the tools and equipment already. To start off it might seem like a lot of money. But over time IF you are a do-it-yourself person, and dont mind getting dirty and dont mind driving somewhere to find where you can get rid of the dirty oil, so its not stacking up in your garage, and you have the time. Thats the way to go.
For some reason, it would seem like i want him to come over here, LOL.
Oster
Old Jan 4, 2007 | 05:43 PM
jphish's Avatar
A lot of automotive stores recycle oil.
Old Jan 5, 2007 | 07:52 PM
caputo's Avatar
First Class Automotive!!! They are fantastic and dependable, and know their crap!
