Question about batteries?
Old Sep 22, 2011 | 05:16 PM
zacksbro11's Avatar
Default Question about batteries?
A co-worker of mine has a brother that works at Braille Battery USA, and i might be able to get a sweet deal on one of their high end lithium-ion batteries but i dont know what specs my car requires. like volts, crank amps, cold crank amps,group,ect. so if u know what the min and/or max of the s2k is please let me know.
Old Sep 22, 2011 | 06:02 PM
JohnsS2000's Avatar
these bits of information might be right on the top of your current battery, especially the CCA(cold cranking amps).. most auto batteries are 12 volt
Old Sep 22, 2011 | 06:22 PM
zacksbro11's Avatar
my battery isnt factory so i wasnt sure if I should go higher or lower with the CCA since I have the amplifier for my stereo system so I didnt know if going higher was bad or if there is a limit
Old Sep 23, 2011 | 07:35 AM
JohnsS2000's Avatar
i would not go lower but going a little higher should not do anything but help the car turn over easier. I have an OEM in my car so Ill see about getting the info and letting ou know what it says
Old Sep 23, 2011 | 08:37 AM
zacksbro11's Avatar
John, Are u going to have all the work done on your car before the wine drive?
Old Sep 23, 2011 | 09:30 AM
Ryuu's Avatar
this is about the better battery ref i found.. lists OEM at 410 cca
https://www.s2ki.com/s2000/topic/353...tery-problems/
Old Sep 24, 2011 | 08:43 AM
JohnsS2000's Avatar
i want to but it looks like I am not going to be able. I put aside some $ and something comes up. I am probably not going to be able to make the drive since I need mechanical work and tires, got to be safe and do not want to risk a dropped valve
Old Sep 24, 2011 | 10:08 AM
zacksbro11's Avatar
thanks john and hope all goes well with the car
lilsam012
Aug 28, 2009 01:21 PM
yuning83
Jun 9, 2008 08:34 AM
sushimaster
May 4, 2007 07:32 AM
jdmgpw04
Jan 30, 2007 10:26 PM
ImBatman
Apr 16, 2006 08:20 PM
