A request for the engineering minded
Old Aug 17, 2009 | 05:28 PM
SortaRican's Avatar
Default A request for the engineering minded
I'm working on a shifter kart project which I want to utilise a paddle shifter setup. The way I want to set it up is a clutch handle on the left side and a rocker typ paddle on the right with the top being upshift an dthe bottom being the downshift.
Now using cables for both up and down I can't figure out how to do it without running into the problem of both cables locking the mechanism in a fixed position. Does that make any sense?
Anyone have any ideas of how to do this?
Old Aug 17, 2009 | 06:14 PM
ComposiMo's Avatar
Is there a reason why you are trying to use two cables, instead of one push-pull type cable?
Old Aug 18, 2009 | 10:52 AM
SortaRican's Avatar
cable isn't rigid enough to push
Old Aug 18, 2009 | 11:14 AM
ComposiMo's Avatar
tell that to the cable steering in my jet-ski... not to mention the thousands of different applications that use push-pull cable setups. One cable, one linkage, simple as pie...
imho, it'd be far easier to buy the proper cable and engineer a simple way for it to be used, than to engineer a twin-cable paddle setup.
[edit]Good place to start... http://www.push-pull.com/
Old Aug 18, 2009 | 11:34 AM
no-cones's Avatar
Teleflex cables, which come in a variety of lengths. They are used as the throttles of some boats and are stiff enough for the push/pull you are looking for.
Just go to any marine store or West Marine.
Old Aug 18, 2009 | 02:12 PM
turn king1's Avatar
as a 15+ year marine machanic, i would agree!
marine cables are very strong! also affordable!
Old Aug 18, 2009 | 03:51 PM
SortaRican's Avatar
I'll look into all those. It would deffinitely make it a whole lot easier.
Old Aug 25, 2009 | 05:19 PM
SortaRican's Avatar
Muwahahahaha!
Old Aug 25, 2009 | 06:34 PM
ArchAngel2K's Avatar
just use the shift linkage off of an actual shifter kart. you pull the shifter towards you to shift up and push forward to down shift. now the way your wanting to do it would be quite unorthodox but doable. the shifters on motorcycle engines are push/pull types of transmissions. all you need to do is find out which directions shifts up and which direction shifts down. once you figured that out you would take the cables and route a long one towards the rear and the short one towards the front or which ever direction the shifter is facing. once it shifts into a gear the lever goes right back into its starting position so you will always have tension on the cables. have free moving paddles so that when you do shift it will move one of the paddles forward and not break the cable.
its a little difficult for me to explain because im more of a hands on sort of person so work with me a little.
Old Aug 26, 2009 | 02:44 AM
SortaRican's Avatar
I hear ya, I'm actually leaning towards a solid linkage that will be run through the frame tubes in spots. I just need to get off my duff and get it welded.
xxlap1xx
Oct 27, 2007 03:29 PM
OhioRacer
Oct 16, 2003 04:30 PM
Gr8nbed11
Sep 17, 2003 08:22 PM
FormerH22a4
May 10, 2003 09:57 PM
